Can Proof by Contradiction Be Validated through Logical Equivalences?
Cole A.
Prove that if x^2 + y = 13 and y \neq 4, then x \neq 3.
N.A.
The proof itself is simple enough: suppose x^2 + y = 13 and y \neq 4. Suppose for the sake of contradiction that x = 3. Then
<br /> \begin{align*}<br /> (3)^2 + y &amp;= 13 \\<br /> y &amp;= 4.<br /> \end{align*}
But this contradicts the knowledge that y \neq 4. Therefore, if x^2 + y = 13 and y \neq 4, then x \neq 3.
The problem I am having is understanding why this is logically valid. Would it be correct to say that, for the statements
<br /> \begin{align*}<br /> A &amp;: x^2 + y = 13 \\<br /> B &amp;: y = 4 \\<br /> C &amp;: x = 3,<br /> \end{align*}<br />
what has been proven is below?
<br /> \begin{align*}<br /> &amp;(A \wedge \neg B \wedge C) \rightarrow B \\<br /> \text{which is equivalent to}~ &amp;(A \wedge \neg B) \rightarrow (C \rightarrow B) \\<br /> \text{which is equivalent to}~ &amp;(A \wedge \neg B) \rightarrow (\neg B \rightarrow \neg C) \\<br /> \text{which is equivalent to}~ &amp;(A \wedge \neg B \wedge \neg B) \rightarrow \neg C \\<br /> \text{which is equivalent to}~ &amp;(A \wedge \neg B) \rightarrow \neg C.<br /> \end{align*}<br />
Is this the proper way to think about the validity of proof by contradiction? (Sorry if this is a dumb question, I'm not a mathematician. What I am finding hard to stomach is identifying x = 3 as the contradictory statement when there are actually three statements that were assumed to be true (and thus possible culprits of the contradiction)).
There is no need to write out the argument in symbolic logic. It works as follows: If x were 3 then y would have to be 4. Since we know that y is not 4, our assumption that x=3 must be false since we obtained an incorrect result with it. Therefore x \neq 4.
You ask why the other assumptions couldn't be the source of the contradiction. We are taking x^2 + y = 17 and y \neq 4 for granted. After all, the goal of the proof is to show that \mathbf {if} these two statements are true, then x \neq 4.
HS-Scientist said:
... then x \neq 4.
I'm sure that you have a typo.
You mean \ x \neq 3 .
@HS-Scientist: Thanks for your answer.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
