I Can someone explain this phenomena?
The discussion revolves around the behavior of two like charges moving at near light speed and the forces preventing them from colliding. It highlights that while observers may disagree on the timing and coordinates of an event, they will agree on whether a collision occurs. The Coulomb force is identified as the primary force acting between same-sign charges, pushing them apart. The conversation also touches on the implications of relativity and how different observers perceive events differently due to their relative motion. Ultimately, the participants seek to understand the underlying physics governing these interactions and the nature of observation in relativistic contexts.
arda
Can someone explain? When two charge moving as fast as possible , what force is acting on for blocking to collide.I mean if you think you are not moving and you are looking 2 charge which are moving as fast as to near light speed, they must collide each other if charge is not increasing according to relativity.But if you moving with charges they must move away to each other.Which force is acting for blocking to charges collide? or is it possible to can 2 observer see same event differently?
arda said:
Can someone explain?When two charge moving as fast as possible , what force is acting on for blocking to collide.
Are you talking about charges of the same sign?
Why must they collide? Why can they not go about their way without interacting?
Why?
Probably the Coulomb force if the charges have the same sign.
If the charges collide, all observers will agree that there has been a collision. They will disagree about the time and coordinates of the collision.
yes they are same
because of charges will create magnetic field as i derived formula and they will have much mass when they are moving as fast as near light's speed
kuruman said:
Why?
coulumb's force says that same charge push themselves and if you looking at the charge when you the same speed you must see they are not moving so there is no magnetic or gravitational forces.
absolutely
actually this is what i want to learn.how is it possible 2 observer can see same event differently without time
i want to say differently this because of the forces they will disagree each other to there is any colliding exists or not
No. They will not disagree on that. You can just use the Lienard Wiechert potential in any frame to calculate the result and it will be the same
Likes arda
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
