Can Sub Lengths Be Equally Divided Among Three TAs?
  • Thread starter Thread starter remaan
    Hard
remaan
Hard problem - dividing the subs !
Anupam brought n > 0 subs, one each of length 1; 2; 3;... ; n, to a grading party.
The three TAs distributed the subs among themselves such that no sub was broken, and each TA
ended up with an equal total length. For what values of n is such a division possible?
At some point, we may use the the sum formula : n(n+1)/2
I tried finding a pattern
n = 1
we have only one sub, doesn't work
n= 2
doesn't work
n=3
doesn't work, as we can't divide this by 3 people.
n=4
doesn't work,
n= 5
it works !
we have 1,2,3,4,5
we can divide by 3 as follows :
one of the TAs will take 5
The other will take 4,1
The third will take 2,3
So, how should I precede with that ?
Do you think this is the right thing ?
It's good that you looked for a pattern right off the start, but I think the main focus is in the formula they gave you (n(n+1)/2). This formula is the what you would use to find 1 + 2 + 3 +...+n. So in the context of this question (n(n + 1))/2 gives you the total length of bread that will be available.
Hope this helps.
Mmm...
Ya But the problem with that is:
Knowing how long bread I have Doesn't solve the problem, since
I Am not Able to break the breads apart.
So, any extra hints ??
Think about each bread as an integer. The fact that we can't break apart any bread when we divide the total length by 3 is important as it tells us something about the expression:
\frac{1}{3} \frac{n(n+1)}{2} , mainly that it can only take on values from a specific set.
Hope this helps
Ok. now suppose I found the two numbers -
are there any hints of how to prove them ?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
