B Can sunglasses fully protect against UV sensitivity?
  • B
  • Thread starter Thread starter DaveC426913
    Wavelengths
Sunglasses may not provide complete protection against UV sensitivity if they only block certain wavelengths, such as UVA, while allowing UVB light to pass through. This raises concerns about the effectiveness of sunglasses that do not darken under UVB light, potentially exposing users to harmful rays. Additionally, UV light can penetrate car windows, which could explain skin reactions from light exposure inside vehicles. The discussion also highlights that while quality sunglasses typically block both UVA and UVB, the correlation between the wavelengths blocked and those triggering photochemical changes is not straightforward. Overall, the effectiveness of sunglasses in protecting against UV sensitivity depends on their specific design and the wavelengths they block.
DaveC426913
TL;DR Summary
I know quality sunglasses *block* UVA and UVB, but what wavelength are they *sensitive* to?
Is there a 1:1 correlation between the wavelengths that a given pair of quality sunglasses blocks and the wavelength that trigger the photochemical change?
For example: if I know my wife I am particularly sensitive to UVB light, and my wife's my sunglasses only darken under UVA light, then I could be getting exposed to UVB light unwittingly.
(Although I guess that would make for a pretty darned useless - and a falsely advertized - product. Which means I guess I answered my own question.)While I'm on the subject: can UV light pass through a car (side) window? If (someone I know) is regularly developing a rash (in the space of ten minutes) from light falling on her skin through a car window, is that likely UV exposure, or is it possible that skin can be sensitive to visible light wavelengths? (Maybe I should move this last question to Medical & Biology.)
hutchphd said:
This seems to indicate that UVA (315-400nm and the least harmful) is the only one that has any significant transmission.
(my annotations in red)
DaveC426913 said:
quality sunglasses ... what wavelength are they *sensitive* to?
... the wavelength that trigger the photochemical change?
my sunglasses only darken under UVA light, ...
"Photochemical change" and "darkening under UVA light" is typical for photochromic sunglasses. Are you perhaps using the word "quality" as a synonym for "photochromic"?
Sure. I simply mean to head off digression into the consequences of sunglasses that are simply tinted or whatever.
Many sunglasses have polycarbonate lenses. Polycarbonate inherently blocks UVA and UVB (cutoff at 400 nm). The unrelated phenomenon of photochromism occurs in a specific lens coating. It can be induced by visible violet and by ultraviolet.
(Fun experiment: a photochromic polycarbonate lens does not darken when held backwards in sunlight)
  • Haha
Likes berkeman, Rive and DaveC426913
DaveC426913 said:
TL;DR Summary: I know quality sunglasses *block* UVA and UVB, but what wavelength are they *sensitive* to?
Just a remark. It's nice to have the excess intensity of visible light reduced, but with the stray UV factored in it's also potentially harmful since the pupils gets unnaturally extended, wide open for any UV bypassing around the edges of the sunglasses.
I don't think it would be anything dangerous for a simple photocromatic lens, but it tells a story that - for example - those fancy round sunglasses are NOT recommended for climbing, sailing or for any UV-intensive environment.
When it matters the edge of device sticks to the skin and does not let any stray UV in.
(random 'climbing sunglass' from the internet)
Likes DaveC426913
I will try that!
