A Can the Magnetocaloric effect be used for heating liquids?
The magnetocaloric effect has potential applications for cooling hydrogen on an industrial scale, as highlighted in a recent article. This process involves using a strong magnetic field to increase the temperature of a metal block, which then cools when placed in contact with a cooler reservoir, allowing for efficient heat transfer. While the principle could theoretically be adapted for heating liquids, it is not more efficient than conventional electric resistance heating methods. The discussion raises questions about the ecological and economic viability of using this effect as a heat pump. Ultimately, traditional heating methods remain simpler and more cost-effective.
Jyrioffinland
TL;DR Summary
Can the magnetocaloric effect be used for heating liquids? Could it be used for an ecologically and economically viable source of energy like a heat pump, generating heat from cold-ish materials?
There's a recent article about cooling hydrogen in an industrial scale with the magnetocaloric effect.
Read the article here
But where does the heat go there? Can it be used for heating liquids? Could it be used for an ecologically and economically viable source of energy like a heat pump, generating heat from cold-ish materials?
I tried to contact the author, Dr. Tino Gottschall at the Dresden High Magnetic Field Laboratory at HZDR but got no answer. You got one?
Likes Andrew Mason
Jyrioffinland said:
TL;DR Summary: Can the magnetocaloric effect be used for heating liquids? Could it be used for an ecologically and economically viable source of energy like a heat pump, generating heat from cold-ish materials?
Read the article herehttps://www.eurekalert.org/news-releases/984338
The idea is somewhat analogous to refrigeration using a gas compressor.
  1. A strong magnetic field applied to a suitable block of metal adds internal energy (increases its temperature). This is analogous to what a compressor does to the refrigerator gas.
  2. While in the magnetic field, the block is placed in thermal contact with a cooler reservoir (eg. liquid nitrogen) and the temperature of the metal block decreases to that temperature. This is analogous to what the condenser in a refrigerator does to the refrigerator gas (the gas circulates through the coil on the refrigerator and heat flow from the coil to the surrounding air).
  3. The metal block is then placed in thermal contact with the thing to be cooled further and the magnetic field is turned off. The block then cools rapidly to a temperature significantly lower than the liquid nitrogen. As it cools, heat flow occurs from the thing to be cooled (hydrogen in this case) to the metal block lowering the temperature of the hydrogen. This is analogous to the Joule-Thompson cooling effect due to sudden expansion of the refrigerant gas and circulation around the space to be cooled
The advantage of the magnetic cooling principle is that it works at much lower temperatures than a conventional gas refrigerator can operate at.
It could be used to heat something but it does not appear to be more efficient in heating than resistance heating. So I expect it would be easier and much cheaper just to use conventional electric resistance heating.
AM
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
