I Can the polarization bound charge density be expressed in vacuum by a wave function?
The discussion explores whether polarization bound charge density can be represented in vacuum using a wave function, noting that vacuum lacks bound charges. It focuses on the behavior of electromagnetic waves, particularly the electric field (E), magnetic field (B), and electric displacement field (D) in vacuum. The participants debate the existence of complex exponential solutions in the wave equations for E and B, questioning if D can accommodate such solutions. The conversation also distinguishes between disruptive and non-disruptive polarization, with an emphasis on linear harmonic polarization. Ultimately, the topic remains theoretical, with participants seeking clarity on definitions and the implications of these concepts.
south
TL;DR Summary
I ask the question assuming that vacuum polarization does not always require the presence of large potentials or large energy densities.
Maybe you can give some more background on your question. In vacuum, there are no bound charges. So it is not clear what you mean.
Thanks DrDu for your help. I'll try to expand.
Nothing practical. Just theory. Monochromatic plane EM wave propagating in vacuum. The wave equation in this case admits a sinusoidal solution, a cosinusoidal solution, and a complex exponential solution.
In EM propagation, the electric field $$\vec{E}$$, the magnetic field $$\vec{B}$$, and other fields, such as the electric displacement $$\vec{D}$$, which interests me particularly, undulate.
When there is no circular or elliptical polarization, the wave equations of $$\vec{E}$$ and $$\vec{B}$$ do not admit the complex exponential solution. Does the wave of the field $$\vec{D}$$ admit this solution?
The answer depends on considering vacuum polarization impossible or possible for any frequency greater than zero. Vacuum disruptive polarization does not occur at any frequency. And what about a non-disruptive polarization, let's say linear harmonic polarization?
I don't dare to deny in advance the possibility of a linear harmonic polarization of the vacuum, without analyzing the subject carefully and in sufficient detail.
south said:
When there is no circular or elliptical polarization, the wave equations of ##\vec{E}## and ##\vec{B}## do not admit the complex exponential solution. Does the wave of the field ##\vec{D}## admit this solution?
Why do you believe this is true? Can you prove it? What exactly do you think the difference is between ##\vec{D}## and ##\vec{E}## in vacuum?
Please define "disruptive polarization" and "non-disruptive polarization".
The conversation has veered into demands that are beyond my reach. I beg your pardon for not being able to continue. Thank you very much and best regards.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
