Can the presence of a field be detected w/o any charge?
In summary: Depends on what we count as detection. The mass of a singly ionized helium atom, the mass of an electron, and the mass of doubly ionized helium can all be measured to better than 10 eV. The first one is the sum of the other two minus 54 eV (the second ionization energy of helium). A +54 eV contribution from kinetic energy and a -109 eV contribution from the electric field. That contribution is measurable.
sasan
Is there anyway to detect the Earth's magnetic field without a compass? or putting it differently,
Is there anyway to detect an electric field without bringing a charged particle in proximity of the field?
Hi sasan, :welcome:
To detect the presence of an electromagnetic field, you need something that interacts with that field. So: no. Only particles with charge can show some interaction.
Very intense fields can lead to pair production, that would be detectable - but the produced particles are charged, of course. It just means you don't need your own particles.
Note that your second question is not equivalent ('putting it differently' is an unfortunate wording) to the first: A compass is a permanent magnet, you could also use the Hall effect or a rotating coil to detect the Earth magnetic field.
Well, if only we had these very intense fields at hand. There's yet no observation of this socalled Schwinger mechanism :-(.
Not yet, but the lasers are making progress towards it.
Pair production at ultraperipheral lead-lead collision is a related effect.
Hey guys, we had a simple question in this thread o_O
Likes davenn, Comeback City and Dale
Wow, this was my first post and I did get my question answered. I am so thankful. I truly am deeply thankful.
Yes! This has a long history in heavy-ion collisions. As far as I know, so far there's also no (clear) evidence for the Schwinger effect there either. It's already tough to get the "normal dileptons" (which are very interesting in themselves, because they provide the most direct probe for in-medium effects of hadrons in the fireball created in heavy-ion collisions).
To get the Schwinger mechanism you need indeed ultra-peripheral collisions to avoid the creation of all this (from the point of view of the Schwinger pairs "background"). On the other hand you need the very large fields, which you may reach formally in such "grazing collisions", however for a very short time only.
The same holds for the large magnetic fields from the spectators in non-peripheral collisions and their impact on the heavy-ion observables in connection with the socalled "chiral magnetic effect".
You can always observe a charge that's in a position when you expected to be in another position. Without seeing any actual change taking place, you can 'infer' that there must be a field there.(Same as a stretched spring could imply that it has a mass hanging on it or that a gravitational field is present.) But of course, that implies there was a change at some time in the past, when the present situation was set up.
But magnetic detectors such as these contain charges.
In principle, the energy density of an EM field gravitates just like any form of mass/energy, I guess, but the effect is way too small to be detectable.
FAQ: Can the presence of a field be detected w/o any charge?
Can a field exist without any charge present?
Yes, a field can exist without any charge present. Fields are physical phenomena that exist in space and are not dependent on the presence of charge. Examples of fields include gravitational fields, electric fields, and magnetic fields.
How can the presence of a field be detected without any charge?
There are several ways to detect the presence of a field without any charge. One way is to use a field detector or sensor, such as a magnetometer or an electric field probe. These devices can measure the strength and direction of a field and can indicate its presence. Another way is to observe the effects of the field on other objects, such as the movement of a compass needle in a magnetic field.
What is the relationship between fields and charges?
Fields and charges are closely related, as fields are created by the presence of charges. Charges have an electric charge, which can create an electric field, and a mass, which can create a gravitational field. The presence and movement of charges can also affect the strength and direction of a field.
Are all fields invisible?
No, not all fields are invisible. Some fields, such as electric and magnetic fields, are not visible to the naked eye, but they can be detected using specialized equipment. Other fields, such as gravitational fields, are not directly visible, but their effects can be observed in the movement of objects.
Can fields be created or destroyed?
Fields cannot be created or destroyed, but they can be generated or altered by the presence and movement of charges. For example, an electric field can be generated by separating positive and negative charges, and a magnetic field can be created by moving electric charges. Fields can also be affected by other fields, such as the way gravitational fields interact with each other.
