- #141
bino
- 180
i know what he said. its just that there has to be a frame of reference for light. that is what i don't understand.
bino said:i know what he said. its just that there has to be a frame of reference for light. that is what i don't understand.
Nenad said:when traveligna th the speed of light, mass becomes infinite, time becomes 0, and distance becomes 0. So in essence, you are everywhere and anywhere in the universe at once.
bino said:you know when your driving in a car the objects closer tothe car look like there are moving faster than the objects farther away. i don't remember what that's called but why doesn't that have an effect on the Lorentz equation?
According to special relativity there is no possible reference frame for light.bino said:is it that there in on frame of reference for light or is it that we just don't have equation to predict lights frame of reference?
and what about this?
Try reading this and see if it helps. It gives a nice history of physics leading up to relativity, the problems earlier researchers encountered, and how relativity solved them.bino said:we astablished in earlier conversation that neither the ship nor the lattes are actually getting smaller that they only appear to be getting smaller from each others view. and with parallax all objects move backward relative to the car, and for nearby objects the speed of change in direction is what the observer considers the normal consequence of his own movement; however, for distant objects the backward change in direction is slow and much less obvious than the forward change in direction relative to nearby objects. It seems as if distant objects move a little slower. it seems that it should have an effect.
I don't know what you mean by "appear". You seem to think that the SR length contraction is an optical illusion in the same sense that the parallax effect is. Not true. All measurements of objects will confirm that they actually do have a shorter length when observed from a frame in which they are moving. They don't just appear to be shorter; in the moving frame they are shorter.bino said:we astablished in earlier conversation that neither the ship nor the lattes are actually getting smaller that they only appear to be getting smaller from each others view.
Parallax, on the other hand, is just a perceptual illusion. Nearby objects merely appear to go by faster compared to background objects. But clearly the actual speed of the objects with respect to you does not depend on the angle of view. Once you understand what causes the parallax illusion, you can account for it. The SR effects depend only on the actual speed, so parallax has no effect.and with parallax all objects move backward relative to the car, and for nearby objects the speed of change in direction is what the observer considers the normal consequence of his own movement; however, for distant objects the backward change in direction is slow and much less obvious than the forward change in direction relative to nearby objects. It seems as if distant objects move a little slower. it seems that it should have an effect.
therefor it just appears contracted from the view of the object at rest.Tom Mattson said:The object isn't "getting smaller". If a rod is moving, then it is smaller than it is in its own rest frame. But nothing actually happens to the rod. It's not as though the rod is physically shrinking by some compressive force.
I still don't understand what you mean by "appears". I can only assume you mean to contrast "appears contracted" with "really is contracted".bino said:therefor it just appears contracted from the view of the object at rest.
Doc Al said:I still don't understand what you mean by "appears". I can only assume you mean to contrast "appears contracted" with "really is contracted".
pervect said:This discussion is starting to get a bit philosophical, but I thought I'd trhow in my $.02, in the hope that it well help more than confuse the issue (we'll have to see how it works out).
Tom Mattson said:The rod is shorter than its proper length in the moving frame.
h8ter said:I thought it had proper length in the moving frame.
To an outside observer it is shorter. Relative to it's own frame, the rod is proper length.
bino said:the rod is shorter when it is moving but only to the at rest observer. but if we are going the same speed as the rod then we know that it is not actually shorter.
bino said:if a ship travels from Earth moving at .99c to a destination 44000 lightyears away. from the view of the ship the trip would take 6270 years but from the view of Earth it would take 44468 years. but from the view of the ship the Earth would be moving at .99c. then wouldn't those numbers be switched?
bino said:i have no problem saying that the length of the ship will be measured shorter. i completely agree with that. but the length is not physicaly getting smaller.
bino said:you have to keep in mind that the length contracts only from the point of view of the stationary object. that's where the disagreement comes from. the ship looks shorter because it is shorter from the point of view of the lattes. the measurements from the equipment are correct from their point a view. the measurement are taken from a point in time. at that point in time the ship will measure to be shorter than its real length. but from the point of view of the ship its length has not changed so the equipment on the ship will say that same thing that it is in fact the same length as when it was stopped. it all matters on the point of view.
Not true. The two frames will disagree as to the distance, since they are in relative motion.bino said:the ship moving at .99c, 44000 lightyears away. and the Earth moving at .99c, 44000 lightyears away. those are the same, the only difference is what is moving from each others perspective.
bino said:right
like i said earlier
onward and forward.
Tom Mattson said:No, because the distance between the Earth and the destination is shorter in the ship frame.
Nenad said:its not philosophical at all. Its Special Relativity.
bino said:i don't understand how they could be different? one is going .99c for 44000 lightyears while the other is at rest. and the same goes for the other.
Tom Mattson said:The distance between Earth and destination is different for the two observers for the exact same reason the length of a rod is different in different frames: Length contraction.
bino said:i understand that
what i don't understand is in the point of view from the Earth the ship is moving but in the point of view from the ship the Earth is moving. right? so then from the point of view of the ship the Earth would then take 44468 years to go 44000 lightyears. and from the point of view from the Earth the trip only took 6270 years.
