sophiecentaur
- 30,116
- 7,386
That makes sense and I notice you only used the word 'wavelength' once then it includes the superposition of a number of wavelengths - as with the classical Fourier transform of a signal burst of finite length. A problem that I have is that this model seems to apply differently from photon to photon - depending on the way it happens to be interacting with matter, each end of its journey - but doesn't that go against the idea that photons have only one parameter (energy) to describe them?Cthugha said:Photons are considered as point particles only in a very limited sense that is not faithful to what most people would naively consider as point particles: If they get absorbed, this happens locally and only at one position. Still, the whole light field is "updated" instantaneously, which gives rise to antibunching and similar effects. However, any single photon state has a finite extent in space and time, where the probability to detect it is non-zero and this extent is given by its coherence volume, which can be small or huge depending on the light source used. The current model of photons is rather that you get probability amplitudes to calculate events such as absorption processes. These probability amplitudes behave pretty much like classical electromagnetic wave packets and thus may also be well described by a wavelength (or a superposition of several of them). The absorption process itself is then localized. However, if you are interested only in things such as simple absorption measurements without taking correlations with measurements at other positions or times into account, the probability amplitudes are sufficient to describe an experiment and you are back at a wave description.
"Still, the whole light field is "updated" instantaneously" and "depending on the light source used." are difficult concepts and to me it seems an artificial mechanism to explain away some of the paradoxes that seem to go go with quantum mechanics. If more than just the energy of a photon is involved, is the idea that you could somehow filter out photons of one kind from another kind (not just the energy involved)?
