Can This Complex Integral Be Proven Rational?
  • MHB
  • Thread starter anemone
In summary, proving the rationality of a tricky integral involves rewriting the integrand in terms of partial fractions, simplifying using algebraic manipulations, and evaluating using properties of rational numbers. Common techniques include partial fraction decomposition, integration by parts, u-substitution, and trigonometric identities. Some integrals may require tricky methods due to complex functions or multiple variables. Applications of this process include solving differential equations, calculating areas and volumes, and analyzing real-world problems in fields such as engineering, physics, and economics.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Prove that \(\displaystyle \int_{-100}^{-10} \left(\frac{x^2-2}{x^3-3x+1}\right)^2\,dx+\int_{\frac{1}{101}}^{\frac{1}{11}} \left(\frac{x^2-2}{x^3-3x+1}\right)^2\,dx + \int_{\frac{101}{100}}^{\frac{11}{10}} \left(\frac{x^2-2}{x^3-3x+1}\right)^2\,dx \) is a rational number.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week POTW.:( You can find the suggested solution as follows:
The polynomial $x^3-3x+1$ changes sign in each of the interval $\left[-2,\,-1\right],\,\left[\dfrac{1}{3},\,\dfrac{1}{2}\right],\,\left[\dfrac{3}{2},\,2\right]$. So it has no zeroes outside these intervals. Hence the integral in question is continuous on the three ranges of integration.
By the substitution $x=\dfrac{1}{1-t}$ and $x=1-\dfrac{1}{t}$, the intervals over $\left[\dfrac{1}{101},\,\dfrac{1}{11}\right]$ and $\left[\dfrac{101}{100},\,\dfrac{11}{10}\right]$ are respectively converted into integrals over $\left[-100,\,-10\right]$.
The integrand
$P(x)=\left(\dfrac{x^2-x}{x^3-3x+1}\right)^2$
is invariant under each of the substitution $x\rightarrow \dfrac{1}{1-x}$ and $x\rightarrow 1-\dfrac{1}{x}$.
Hence the sum of the three given integrals is expressible as
\(\displaystyle \int_{-100}^{-10} \left(\frac{x^2-2}{x^3-3x+1}\right)^2 \left(1+\dfrac{1}{x^2}+\dfrac{1}{(1-x)^2}\right)\,dx \)
But
$\dfrac{1}{P(x)}=\left(x+1-\dfrac{1}{x}-\dfrac{1}{x-1}\right)^2$
So the last integral is of the form \(\displaystyle \int u^{-2}\,du \).
Hence, its value is
$ \left.-\dfrac{x^2-x}{x^3-3x+1}\right|_{-100}^{-10}$, which is rational.
FAQ: Can This Complex Integral Be Proven Rational?
What is the purpose of proving the rationality of a tricky integral?
The purpose of proving the rationality of a tricky integral is to determine if the integral can be expressed as a rational number, meaning it can be written as a fraction of two integers. This can help simplify the integration process and provide a more precise solution.
What are the steps involved in proving the rationality of a tricky integral?
The first step is to rewrite the integrand in terms of partial fractions. Then, use algebraic manipulations to simplify the fractions and combine them into one expression. Next, use the fact that the integral of a polynomial is a rational number to evaluate the integral. Finally, check the answer using a calculator or by hand to confirm that it is a rational number.
What are some common techniques used to prove the rationality of a tricky integral?
Some common techniques include using partial fraction decomposition, integration by parts, u-substitution, and trigonometric identities. It may also be helpful to use algebraic manipulations and properties of rational numbers.
Why do some integrals require tricky methods to prove rationality?
Some integrals may require tricky methods to prove rationality because they involve complex functions or multiple variables. These types of integrals often require a combination of techniques and creative problem-solving to simplify and evaluate.
What are the applications of proving the rationality of a tricky integral?
Proving the rationality of a tricky integral can be useful in various fields of mathematics and science. It can help in solving differential equations, calculating areas and volumes, and determining probabilities in statistics. It can also be used in engineering, physics, and economics to model and analyze real-world problems.
