Can This Differential Equation Be Solved by Separation of Variables?
The discussion centers on solving a differential equation related to the velocity of an object falling through air using the separation of variables method. The initial attempt involves integrating both sides from time 0 to t but encounters confusion regarding the correct form of the equation. Participants clarify that the equation should be expressed as m(dv_y) / (v_y - v_ter) = -bdt and emphasize the importance of proper notation. There is a correction regarding the integration process, indicating that the methodology was flawed from the first step. The conversation highlights the need for clear communication and accurate mathematical representation in problem-solving.
SpaceIsCool
We solved the differential equation (2.29),
3jQQorlME_t__2tW6a8kcnYMlu3IQt04D8vDrtjBPfupq1HsNrmZUl4xD1bMqDKY3ssnC-gk-e0sg9TyVu5zgFWU6VsDs5dw.png
, for the velocity of an object falling through air, by inspection---a most respectable way of solving differential equations. Nevertheless, one would sometimes like a more systematic method, and here is one. Rewrite the equation in the “separated” form
XX1f9LT1V4iwLFhOj0k17drHhyTjkFlbPurmlbw2iveZyOY70N-4lnsJ8nUSC3cy-BfGiq8hJ43C7kc4ynZMgcGMLMb88cfc.png
and integrate both sides from time 0 to
hFE8d86mE5qF60vFSYngvVUpWFO68N1uVz5xGeu-sdHjYX8yyDs4qyalPiGohlD-DzZB5cO0NK1No--OW9J5HFcXei2jS3kR.png
to find
G2YEY28crCFfirUT4r7rOHNBaqxt3skHs4ekGyy7QIkYNYJMb9qQRwnt8Y4FDIwi7g143bzRjZdRbStBbwEfDVbrHMPtZ2wq.png
as a function of
8O4uKQnrmKWgR9UXYtK_PW1xcKLsdhnUg2degFW--u1CO84TGSRm2KcGLfcbAWyOdelH6M3yuu9tGdKH2IV5ExkbePnjzWzD.png
. Compare with (2.30).
[/B], equation to integrate/solve.
5QaZ9UrgA6wAB6mhn4OqOWzSES5iMKWq5HeIyNUGso3ndh-iMCdNLtkStb_BTCMFG1FJftZiANbli2Zo348uSWuMx19EXBa9.png
, answer should like this.
Integrate both sides of the separated form of the differential equation from time 0 to t and then write
FNV42vu_LJT7kC0fuNcaHis6ixZXlVrOAWtlALmrPOaeDAfRi_eI6YIiiGtmYj4_vUbVjdFCqhOINDnhpPXX6F29AvH3d_5M.png
. After this, I will compare my answer to equation 2.30 which is
AATrdWCxsgaZiMrK_EVvJA8r04k2mPrRD1RkRyOQjLMBfO8Jfd-cB-T9FosAtd6RnF_lwC5ufVhlxA1bD43bwv94WCNop01A.png
. This gives
uVh4fi89LFMNhydQFiEj8Zqg5PcabxW1p9-KV6nFoYOPqGd4OFBd8OASdAY4nJzF3TsXecQhJvXOE85om7SsDJ8T7SuvcY7F.png
. This is as far as I could get. I don't know how to get it into the form v_y(t).
  • 3jQQorlME_t__2tW6a8kcnYMlu3IQt04D8vDrtjBPfupq1HsNrmZUl4xD1bMqDKY3ssnC-gk-e0sg9TyVu5zgFWU6VsDs5dw.png
  • XX1f9LT1V4iwLFhOj0k17drHhyTjkFlbPurmlbw2iveZyOY70N-4lnsJ8nUSC3cy-BfGiq8hJ43C7kc4ynZMgcGMLMb88cfc.png
  • hFE8d86mE5qF60vFSYngvVUpWFO68N1uVz5xGeu-sdHjYX8yyDs4qyalPiGohlD-DzZB5cO0NK1No--OW9J5HFcXei2jS3kR.png
  • G2YEY28crCFfirUT4r7rOHNBaqxt3skHs4ekGyy7QIkYNYJMb9qQRwnt8Y4FDIwi7g143bzRjZdRbStBbwEfDVbrHMPtZ2wq.png
  • 8O4uKQnrmKWgR9UXYtK_PW1xcKLsdhnUg2degFW--u1CO84TGSRm2KcGLfcbAWyOdelH6M3yuu9tGdKH2IV5ExkbePnjzWzD.png
  • 5QaZ9UrgA6wAB6mhn4OqOWzSES5iMKWq5HeIyNUGso3ndh-iMCdNLtkStb_BTCMFG1FJftZiANbli2Zo348uSWuMx19EXBa9.png
  • FNV42vu_LJT7kC0fuNcaHis6ixZXlVrOAWtlALmrPOaeDAfRi_eI6YIiiGtmYj4_vUbVjdFCqhOINDnhpPXX6F29AvH3d_5M.png
  • AATrdWCxsgaZiMrK_EVvJA8r04k2mPrRD1RkRyOQjLMBfO8Jfd-cB-T9FosAtd6RnF_lwC5ufVhlxA1bD43bwv94WCNop01A.png
  • uVh4fi89LFMNhydQFiEj8Zqg5PcabxW1p9-KV6nFoYOPqGd4OFBd8OASdAY4nJzF3TsXecQhJvXOE85om7SsDJ8T7SuvcY7F.png
DrClaude said:
@SpaceIsCool In case you don’t understand that, your first relavent equation will look like:
$$(md\upsilon_y) / (\upsilon_y - \upsilon_{ter}) = -bdt$$
The code is:
Code:
The code is:
Code:
Hello,
I'm not asking about latex help. Do I need to fix this before this question can be answered? I'm kinda new to using the forum.
You can leave it as is for now, but please write the equations directly in the post instead of inserting them as figures. It makes the post harder to read and difficult to quote.
Likes YoungPhysicist
Okay. I understand. Thanks!
##v''=\frac{d^2v}{dt^2}##, not ##\frac{dv}{dy}##. So your whole methodology from step 1 is incorrect.
If you had a course in differential equations, didn't they teach you how to solve an n'th order linear ordinary differential equation with constant coefficients?
Perhaps the differential equation is ##m\dot{v_y}=-b(v_y-v_{ter})##? if yes then what you doing seems correct except from the last integration step which should be
$$m(\ln|v_y-v_{ter}|-\ln|v_{y_0}-v_{ter}|)=-bt$$
This after some algebraic manipulation I believe it agrees with your equation (2.30).Otherwise if the ODE is exactly as you write at OP then as @Chestermiller notes, you go wrong from the first step cause it is ##\ddot{v_y}=\frac{d^2v_y}{dt^2}## and its NOT ##\ddot{v_y}=\frac{dv_y}{dt}## which you seem to use in order to do separation of variables.
