I Can tiny gas bubbles cause discomfort in body cavities?
Air rises to the highest points in body cavities like the peritoneal and pleural spaces due to buoyant forces acting on gas bubbles, which are typically submerged in a small amount of fluid. This fluid creates surface tension that helps keep organs in place. While gases like CO2 can dissolve easily in body fluids, tiny nitrogen bubbles, often released during decompression, can cause significant discomfort and take longer to dissolve. Large amounts of gas in these cavities can lead to complications, as experienced after laparoscopic surgery where CO2 is used to create space for surgical procedures. Overall, managing gas levels in body cavities is crucial to prevent discomfort and potential health issues.
tanas
Can someone explain why air rises to the highest point in the body cavities like peritoneal/pleural?
For the same reason that [a heavier than flesh] fluid sinks to the bottom of such cavities.
Bubbles?
Buoyant force? I guess that that we can assume that gas in cavities is actually submerged in fluid? There is tiny amount of fluid in this cavities that keep organs and serous surface stick to each other by surface tension.
Although there could well be small amounts of gas in amongst our organs, they are likely to be dissolved eventually in the fluids. Any small amounts of gas can give severe discomfort, as in decompression sickness, which is suffered by divers and air embolisms. CO2 is not too much of a problem because it dissolves but tiny nitrogen bubbles which have come out of solution as the pressure reduces take a long time to dissolve, once they have joined together. Hence, divers decompress slowly enough to let the body get rid of the tiny bubbles.
Large amounts of gas are definitely not a good idea. I had laparoscopic surgery, some years ago and they fill your peritoneum with CO2 to separate out the organs so that they can work in there. The sensation afterwards was truly weird. I likened it to having a bag of groceries in there until the CO2 gradually passed out (via the normal route!) and the organs nestled together again, properly.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
