- #36
DiracPool
- 1,243
- 516
Don't you agree?
https://www.youtube.com/watch?v=S8ecCnn5o1o
Jon_Trevathan said:The Stanley Miller and Harold Urey experimental creation of amino acids and Leslie Orgel's formation of adenine are necessary constituents of life but do not address the near statistical impossibility that many scientists have calculated for the "Origin of Life" in our universe.
Jon_Trevathan said:. In effect, a quantum system may 'feel out' a vast array of alternatives simultaneously. In some cases, this speed-up factor is exponential (Farhi and Gutmann, 1998). So the question is: Can quantum mechanics fast-track matter to life by 'discovering' biologically potent molecular configurations much faster than one might expect using classical estimates?"
Our presence here is, in fact, a statistical certainty: we are here. Otherwise, who are you talking to?DiracPool said:Unfortunatley, as a biologist I have to agree with this. Our presence here is a near statistical impossibility in my opinion.
So... our presence is a near impossibility, but life on Mars is unsurprising?I wouldn't be surprised if we found life on Mars, so I don't think anybody knows
DiracPool said:Jacob Bronowski is arguably the coolest scientist to ever walk the planet. He had a good idea that DNA may have been initially formed in Ice. Makes more sense than an underwater thermal vent like we always see.
SW VandeCarr said:Given the availability of the chemical constituents of life and what we know about carbon chemistry, I don't understand this idea that life is such a low probability occurrence.
SW VandeCarr said:You do seem to be taking both sides of the issue of the probability of life in the universe.
The complexity is mind blowing.
You need to get away from the books more: it's brought up all the time - and it is not something that actually concerns empirical science ... it does not matter how much life was needed to kick it off. Empirically, you can only hope to find out how much there actually was. The rest is just math and philosophy.I think the ... problem here is to find out ... just how much of life there needed to be to begin. That's an issue that isn't often brought up if you're catching my drift.
Chronos said:I think prions are a great clue how nature may have managed the feat of abiogenesis.
Sure, welcome to the world of O-GlcNAc modification:mfb said:@gravenewworld: Can you break a cell with a single modification of a PTM molecule somewhere?
The pure number of possible arrangements is not relevant, as long as different arrangements do not lead to different results
Simon Bridge said:The large number of different possible outcomes from simple changes just reinforces the idea that not a lot of complexity is needed to kickstart things - the complex outcomes are built-in to the simple rules at the start.
The trick is not to let the complexity overwhelm you.
Well, where does that change in cancer cells come from? If a DNA mutation is the source, we are back to DNA again.gravenewworld said:Ah but different arrangements do lead to different results. How about a simple example? Sialic acids are carbohydrates that often cap the ends of glycan structures. Alpha 2,3 linked sialic acids appear often in healthy functioning cells. In cancer cells, glycans on the surface often have overexpressed alpha 2,6 linked sialic acids which aids in their metastasis and tumor progession. Sialic acids are also post translationally modified even further with acetate groups. Depending on where an acetate group is added, it can promote tumor progression, or in the opposite direction, promote apoptosis.
The only mention of "single [anything]" I see is "A single copy of the OGT gene is located on the X chromosome in humans and mice and OGT gene deletion in mice was embryonically lethal, demonstrating that OGT activity/O-glycosylation is vital for life [21].", indicating that those molecules are generated based on DNA sequences.Sure, welcome to the world of O-GlcNAc modification:
http://cardiovascres.oxfordjournals.org/content/73/2/288.full
http://www.ncbi.nlm.nih.gov/books/NBK20725/
I am sure the first artificial biological life will be a very simple unicellular organism, and probably very similar to an existing natural cell. Probably more like a copy than a completely new design.Just because one might be able to control DNA doesn't mean that one can create a properly functioning cell when everything from environment to cell-cell communication and uncontrollable (at least for now) PTMs are going to change the final output. It's science though, nothing should ever be ruled impossible. One day we might be able to create life from scratch, but we'll loooonnng be dead.
ChrisJA said:The first life was based on RNA
Fermifaq said:It is quite likely that numerous lifelike systems emerged in many locations, many times and continued to do so for millions of years...
Early life was probably very fragile and inefficient, it is highly likely that many symbiotic relationship where formed...
While one cannot rule out a single very lucky complex event it is far more likely that 'life like things' emerged and became extinct time and again over periods of millions of years...
Today's single celled organisms are almost certainly far more hardy and efficient than early life...
In the media you will often hear undersea vents being cited as a possible source for the origin of life. This is almost certainly nonsense as the 'chemical freedoms' in such environments far out weigh the 'chemical constraints',so it would be like trying to paint a Van goh in in a typhoon...
ndjokovic said:This machine is made of 2062 amino acid molecules. Covalent bond and hydrogen bonds is what makes these molecules joined (electric forces). This machine is not constructed like this in the first time, but it is constructed by another machine called Ribosome in the form of string of molecules, then this string of molecules fold because of electric forces into parts which then make the working machine. But the whole process takes only nanoseconds:
A small machine of only 100 amino acids molecules can take some 10100 different configurations to fold. If it tried these shapes at the rate of 100 billion a second, it would take longer than the age of the universe to find the correct one. Biologists now don't have an idea just how these molecules fold in nanoseconds. Only quantum physics can explain this phenomenon
These are two good examples of processes where quantum mechanics is important for understanding biological phenomena.In the recent 3 years, quantum physics is becoming more and more interesting in biology, since the discovery of the "spooky action at a distance" in migrating birds:
and in plants:
http://www.kurzweilai.net/evidence-that-photosynthesis-efficiency-is-based-on-quantum-mechanics
And this, in my personal and professional opinion, is complete and utter ********.There's also a recent discovery of quantum vibrations in 'microtubules' inside brain neurons:
http://www.sciencedaily.com/releases/2014/01/140116085105.htm
I am sorry because I meant by the "whole process" only the folding, not the work done by the Ribosome.Ygggdrasil said:Protein folding does not take place on the nanosecond timescale. First, ribosomes synthesize proteins at a rate of about 10-20 amino acids per second (http://bionumbers.hms.harvard.edu/search.aspx?log=y&task=searchbytrmorg&trm=100059&org=%), so synthesizing a ~2000 amino acid enzyme would take at least ~100 seconds, and folding occurs during synthesis. Even in artificial studies of protein folding (e.g. laser temperature jump studies), the folding rates of the fastest folding proteins are on the order of microseconds (although individual elements of the protein can probably become structured on the tens-hundreds of nanoseconds timescale) (see Kubelka, Hofrichter and Eaton. 2004. The protein folding ‘speed limit’. Curr Opin Struct Biol 14: 76. http://dx.doi.org/10.1016/j.sbi.2004.01.013 ).
But there's still the problem of the nonlinear and asymmetric relation between folding/unfolding and temperature which those models can't explain.Ygggdrasil said:How proteins fold without having to sample all possible configurations (Levinthal's paradox) is a solved problem. Proteins have evolved to have a "funnel-shaped" energy landscape, such that the energetics of their interactions will guide them toward the correct, native structure (see, for example, Dill and MacCallum 2012. The Protein-Folding Problem, 50 Years On. Science 338:1042. doi:10.1126/science.1219021). Furthermore, it is not necessary to use quantum mechanics to explain protein folding as computer simulations based on only classical physics can model protein folding very well (Lindorff-Larsen et al. 2011. How Fast-Folding Proteins Fold. Science 334: 517 doi:10.1126/science.1208351) (in fact, we understand the folding of fast-folding proteins much better than we do the folding of slow-folding proteins).
The discovery of quantum vibrations in the brain is fact. I think you may disagree with the theory that gains a support with this discovery, but that's not how you should talk about it. I am not a supporter of this theory, I need more information to judge it. But if we want to attack it, we should find some weaknesses. Einstein didn't like quantum physics, he saw it as a nonsense theory, but experiments proved Einstein was wrong. A thing like for example Delayed Choice Quantum Eraser can sound weird and nonsense, but it is fact and proved by experiments.Ygggdrasil said:And this, in my personal and professional opinion, is complete and utter ********.
