Can we increase force of an open nozzle that runs on compressed air ??
The discussion focuses on an operational challenge with an air knife nozzle that is not generating sufficient force to remove stagnant water. An operation engineer reports that maintenance has increased the number of inlets and outlets to the air knife but questions whether this will enhance performance. Forum members suggest providing more specific details about the application, such as the type of stagnant water, orifice size, and the distance from the air knife to the surface. They emphasize that understanding the compressor's ability to maintain pressure at the required flow rate is crucial for effective analysis. The conversation highlights the importance of precise problem definition for troubleshooting.
moneybitsingh
How did you find PF?: Online browsing
Hi, i am an operation engineer. We are having a bottleneck where a nozzle ( air knife/ long strip with multiple orifice), used for removing stagnant water is not generating enough force and some water still stagnates. Maintainance engineer have increased the number of inlet to airknife from 1 to 2( both from same centralised industrial compressor of 5 bar.) and outlet from 2 to 6. Will it increase the force and can remove extra water??
Someone answer please..
Could you be a bit more specific for someone to be able to help you out.
Stagnant water where - pools of water on the floor, droplets on a surface just washed, ...
What size orifice , spacing.
Distance of air knife to surface.
Can the compressor keep up the pressure at 5 bar, at the Q flow, which relates to orifice sizing.
A problem well stated is a problem easily analyzed.
Be patient please.
Welcome to PF.
Please keep in mind that it is against the PF rules (see INFO at the top of the page) to BUMP up your post unless it has gone unanswered for at least 24 hours. Thank you.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
