Can we say that a line is a particular case of a triangle
In summary, the conversation discusses the concept of a straight line being a triangle with equal sum of two sides and two angles of 0°, as well as a triangle with two angles of 90°. The conversation also explains the proper definition of the sine function on a unit radius circle and the relationship between angles and chords. It is mentioned that a right triangle can be seen as a straight line when one angle is 0° and this concept is further illustrated using the example of a stick and its shadow.
prashant singh
56
I think we can say that a straight line is a triangle in which sum of two side equals third side in which two angle equals 0° and the middle angle equals 180°, but can we say that a striaght line is a triangle with two angle equals 90°, I am saying this because my sister is not beliving that sin(90°) = 1, she is saying that for proving sin(90°) = 1, I am making the triangle as a straight line but these ratios are only applicable for triangles , I told her that there will be no triangle with two angle equals 90° therefore I have to make it as a straight line.
Mathematics news on Phys.org
The sine function is defined properly on a unit radius circle not a triangle.
When you do it this way, ##\theta## is the half-angle subtended by a chord. Half the length of the chord is the sine of the half-angle.
Draw a line of symmetry through the diagram to recover the usual soh cah toa triangles.
When the angle is 90deg, then the chord is just the diameter ... which is 2 for the unit circle.
Half the diameter is 1 ... hence sin(90)=1.
Similarly, if you draw a tangent to the circle at the symmetry line, the length of the tangent inside ##\theta## is called "the tangent of theta".
The distance along an angle line to the tangent is called the secant.
cosine, cotangent, and cosecant, are what yuo get with the above definitions using the complimentary angles.
Also see:
https://www.mathsisfun.com/geometry/unit-circle.html
You can argue that a rt-triangle becomes a line segment when one angle is zero. The other two angles are 90deg, two sides overlap and one has length zero... but it is easier to show on a circle.
Likes 256bits
Wow great sir thank a lot
Also see:
Basicaly at the end u are saying that we can say that a right angle triangle will become straight line when one of its angle is zero. I got the idea of unit circle.thanks a lot sir.
Likes Simon Bridge
It also works, and is less abstract, as a projection:
... if you have a stick upright on flat ground, with parallel light coming vertically down, then it's shadow has zero length.
If you tilt the stick an angle A to the vertical, the shadow gets longer ... when A=90deg, the shadow is the same length as the stick.
If the stick is 1 meter long, then the length of the shadow is sin(A) meters.
Likes prashant singh
FAQ: Can we say that a line is a particular case of a triangle
1. Can a line be considered a triangle?
No, a line cannot be considered a triangle. A triangle is a two-dimensional shape with three sides and three angles, while a line is a one-dimensional shape with no sides or angles.
2. Is a line a type of triangle?
No, a line is not a type of triangle. A line is a basic geometric element, while a triangle is a specific type of polygon.
3. Can we say that a line is a degenerate triangle?
Yes, a line can be considered a degenerate triangle. A degenerate triangle is a triangle with one or more of its sides having a length of zero. In this case, the degenerate triangle would be a line.
4. How does a line differ from a triangle?
A line differs from a triangle in several ways. As mentioned before, a line is one-dimensional while a triangle is two-dimensional. Additionally, a line has no sides or angles, while a triangle has three sides and three angles. A line also has infinite length, while a triangle has finite length.
5. Why is it important to understand the difference between a line and a triangle?
Understanding the difference between a line and a triangle is important in geometry and other areas of mathematics. It allows us to accurately describe and classify shapes, and to use their properties to solve problems. It also helps us to build a foundation for more complex concepts in geometry.
