B Can we use molecular speed of gas formula also for the air?
The molecular speed of gas formula, v = √(3RT/M), can be applied to air, which is a mixture of gases, by using its average molecular weight of approximately 28.96 g/mole. Air primarily consists of nitrogen and oxygen, both diatomic gases, allowing for effective modeling as an ideal gas. The computed root mean square (RMS) velocity of air correlates with the speed of sound. In an ideal gas, the speed of sound is proportional to the RMS molecular speed, with the relationship expressed as vs/vm = √(γ/3), where γ = Cp/Cv = 7/5 for diatomic gases. This demonstrates that the molecular speed formula is valid for air and provides insights into its acoustic properties.
Lotto
TL;DR Summary
Can we use molecular speed of gas formula also for the air? I mean if we can use molecular mass of the air.
Molecular speed of gas is generally $$v=\sqrt{\frac{3RT}{M}},$$where R is gas constant and M is molecular mass. Can we use this formula for the air as well, when the air is a mixture of different gasses?
You can use the molecular speed of gas for air.
I believe the computed RMS velocity gives you the speed of sound.
The molecular weight of air is close to 28.96 g/mole.
Given single percentages and integer atomic weights.
N2 + O2 + Ar = (14*2)*0.78 + (16*2)*0.21 + (40)*0.01 = 28.96 g/mole.
You can model the air as a diatomic ideal gas and get some good results. Air is made mostly of nitrogen and oxygen, both of which are diatomic gasses.
For a given gas, the two are proportional.
https://physics.stackexchange.com/questions/78879/simple-explanation-of-relation-between-speed-of-sound-and-r-m-s-speed said:
In an ideal gas, the speed of sound ##v_s## is related to the r.m.s. molecular speed ##v_m## by $$\frac{v_s}{v_m}=\sqrt{\frac{\gamma}{3}}$$where ##\gamma## = ##C_p/C_v## = 7/5 for a diatomic gas.
The article above goes on to provide an explanation for the relationship.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
