CookieSalesman
- 103
- 5
I thought about this pretty hard, can windows frost over in space? I'm pretty sure they don't or can't after giving it a bit of thought. This is just a curiosity of mine.
So first I believe the correct question that we're trying to answer is:
Can a window get colder than interior air faster than the interior air can? Because in order to cause condensation/frosting it's only possible if the window is much colder.
I think this leads to 2 scenarios, one where the spacecraft is in thermal equilibrium, roughly speaking, and another situation where it is cooling down over a significant period of time.
I've given it a bit of thought but I'm not clear what's going on. First, the spaceship is in a vacuum and simply does not lose heat due to kinetic loss. It can only lose heat due to electromagnetic radiation.
However, because the radiation passes from the inside air through the window, how could the window possibly lose enough heat? The radiation from inside and thermal contact with the window should bring the window into near equilibrium, I think.
Is this correct?There are depictions like in the iron man scene where iron man goes out into low stratosphere and his visor frosts, however this is only possible because the heat loss from physical contact first of all greatly exceeds that of EM radiation. Consequently his visor gets cold very quickly because it's the first interface with the extremely cold outside atmosphere. The inside is more insulated and much much hotter than the sub-zero outside temperature and visor. I believe this is very unequal to the spaceship cockpit situation.
