Can Worm Gear & Helical Gear Move?
  • Thread starter Thread starter Shmupsy
    Gear
A worm gear can transmit power in one direction only, meaning it cannot drive the worm gear when the worm is turned in reverse. While the worm can rotate backwards and forwards, the helical gear remains locked and cannot influence the worm's movement. The interaction between the worm and worm gear is crucial, as attempting to turn the worm gear will lead to damage rather than movement. Self-locking worm drives prevent the output from driving the input, depending on specific mechanical factors like lead angle and friction. Understanding these dynamics is essential for effective application in gear systems.
Shmupsy
Can a worm gear that's attached to a helical gear (so that the helical gear is locked, but the worm gear isn't) go backwards and forwards?
Assuming that by "worm gear" you mean "worm", and by "helical gear" you mean "worm gear" (if not, disregard this because I've misinterpreted your question; the terminology for worm drive mechanisms isn't straightforward so I think this is what you're asking about). The worm can transmit power backwards and forwards, but the worm gear cannot transmit power through the worm. (So input always goes to output, and output never drives inputs). Only transmits in one direction from a system point of view. Again, you could run the worm in reverse (flip your direction of input), but that's distinctly different from trying to turn the worm gear to turn the worm. Think about it like this; the worm has to spin on an orthogonal axis to the worm gear to make the worm gear turn, and it does so by having the teeth meshing parallel and spinning like a barber post sign thing. If you tried to run the worm by rotating the worm gear, you end up in essence trying to shear the teeth off the worm, and trying to torque the worm off its shaft.
I'm probably not describing it well, so here's an article from wikipedia on worm drives. Personally I think the best way to see it for yourself it to take a simple setup and try to turn the output shaft with the worm gear on it attached to the worm, and look at the interaction to see why it won't budge. It's intuitive then.
"Unlike with ordinary gear trains, the direction of transmission (input shaft vs output shaft) is not reversible when using large reduction ratios, due to the greater friction involved between the worm and worm-wheel, when usually a single start (one spiral) worm is used. This can be an advantage when it is desired to eliminate any possibility of the output driving the input. If a multistart worm (multiple spirals) then the ratio reduces accordingly and the braking effect of a worm and worm-gear may need to be discounted as the gear may be able to drive the worm.
Worm gear configurations in which the gear can not drive the worm are said to be self-locking. Whether a worm and gear will be self-locking depends on the lead angle, the pressure angle, and the coefficient of friction; however, it is approximately correct to say that a worm and gear will be self-locking if the tangent of the lead angle is less than the coefficient of friction."
--http://en.wikipedia.org/wiki/Worm_driveAgain, please forgive me if I've misunderstood your question.
You interpreted my question right, but I'm still a bit confused. Can a self locking worm drive be turned *at the worm* both backwards and forwards?
Like these pictures, for example.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
