I Can you calculate the probability of a complex logic expression?
The discussion revolves around the calculation of the probability of a complex logic expression, specifically ((A ∨ ~B) ∨ (C -> D)), which simplifies to A + ~B + ~C + D using Boolean algebra. Given the probabilities p(A) = 0.3, p(B) = 0.99, and p(C) = 0.92, the expression is known to be true, leading to the question of whether D can be calculated. It is concluded that D cannot be determined solely from the provided information without knowing the dependencies or conditional probabilities among A, B, C, and D. However, it is suggested that D could be true under certain conditions, indicating that while it may not be calculable, its truth value can be inferred based on the other variables.
yeet991only
TL;DR Summary
Any logical expression can be simplified to AND , NOT , OR. But these are same as intersection , negation and reunion in probability.
Suppose this expression : ((A ∨ ~B) ∨ (C -> D))
This simplifies to : A + ~B + ~C + D , using boolean algebra.
Now suppose i know that this expression is true: p( ((A ∨ ~B) ∨ (C -> D)) ) = 1;
and I also know that p(A) = 0.3 , p(B) = 0.99 , p(C) = 0.92 .
but the probability of the expression is actually: p(A ∪ ~B ∪~C ∪ D) = 1
So can you calculate D from that? (Normally you could, but the question is if combining logic and probability like this is valid).
Also clearly (C -> D) isnt the kind of arrow that you would use in a bayesian network or stuff, because it reduces to p( ~C or D) , but in graphs it is the bayes formula for such arrow : p(C | D) = p(D|C) * p(C) / p(D).
yeet991only said:
TL;DR Summary: Any logical expression can be simplified to AND , NOT , OR. But these are same as intersection , negation and reunion in probability.
No. From just the information given we don’t know if the probabilities of one are dependent on the others. Without knowing that they are independent or mutually exclusive or knowing their conditional probabilities, ##p(D)## cannot be calculated from the given information
A related area is probabilistic logic programming https://en.m.wikipedia.org/wiki/Probabilistic_logic_programming
Any logical expression can also be simplified to NAND only, NOR only, and if one allows ##c\to\text{false}##, also by implication only as ##c\to\text{false}## is NOT c.
That expression can be write as ##((A\vee \neg B) \vee (\neg C \vee D))##, and now one can dispense with the parentheses, yielding ##(A\vee \neg B \vee \neg C \vee D)## -- and also ##((A \vee \neg B \vee \neg C) \vee D)##. I'll use that final form in just a bit.
One obvious solution is that D is always true, in which case P(D) = 1. There are other solutions. Note that it doesn't matter what D is in the case that ##(A \vee \neg B \vee \neg C)## is true. However, we must have D being true whenever ##(A \vee \neg B \vee \neg C)## is false. Note that D always being true satisfies this requirement, but so does ##D = \neg(A \vee \neg B \vee \neg C) = (\neg A \wedge B \wedge C)##. Given the sited probabilities, that D is true (but not necessarily always true) seems quite likely.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
