Can you calulate a transformer secondary resistance by using load regulation %
To calculate the internal resistance of a transformer’s secondary winding using load regulation, the voltage difference between no-load and full-load can be determined by multiplying the voltage by the regulation percentage. For a 300 VA transformer at 45 Volts with a 10% regulation, this results in a voltage difference of 4.5 volts. The secondary series resistance per winding is then calculated as 4.5 volts divided by 3.3 amps, yielding approximately 1.36 ohms. It is important to consider the primary resistance, which can be reflected to the secondary side and may significantly impact regulation. In scenarios where both resistances are equal, the secondary resistance should be taken as half of the calculated value to account for both contributions to regulation.
mp3streetpart
If I had a step down transformer of 300 VA in size at 45-0-45 Volts@3.3 Amps with a regulation of 10% could I do the following to calculate the internal resistance of the secondary winding for my power supply circuit?
Voltage * Regulation 10% to work out the voltage difference between noload and full load.
45 Volts* .1 = 4.5 volts
Secondary series resistance per winding
4.5 Volts/3.3 amps = 1.36 ohms
I know there is inductance as well but at the moment I am ignoring it.
I need to put values into circuit maker student edition to reflect the real world.
You need to take the primary resistance into account. It is reflected by the square of the turns ratio to the secondary, and is a quite significant contributor to regulation.
If a transformer is well designed, typically the reflected value of the primary resistance on the secondary side will be the same as the secondary intrinsic resistance (equal copper losses in both windings being the goal). Often this is close to the truth, but not always. However, in the absence of any possibility of measuring both windings' DC resistance, the best you can do is to take them to be equal.
Since both the secondary resistance AND the reflected primary resistance will contribute equally to the regulation (if the copper losses both windings are equal), you should take the secondary resistance to be half of your calculated value.
Ok I forgot about the primary resistance thanks for that.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
