MHB Can you factor the following two polynomials?
  • Thread starter Thread starter DrLiangMath
    Polynomials
The discussion centers on the factorization of the polynomials x^4 + 4 and x^4 + 3x^2y^2 + 2y^4 + 4x^2 + 5y^2 + 3. Participants note that x^4 + 4 cannot be factored over the integers or real numbers, but can be expressed using complex factors. The polynomial can be rewritten as (x^2 + 2 + 2x)(x^2 + 2 - 2x) through a specific manipulation. Additionally, the equation x^4 + 4 = 0 has four imaginary solutions that form conjugate pairs, leading to further factorization. The conversation highlights the complexity of polynomial factorization and the existence of imaginary roots.
DrLiangMath
Can you factor the following polynomials over integers?
[math] x^4 + 4[/math]
[math] x^4 + 3 ~x^2~y^2 + 2 ~y^4 + 4 ~x^2 + 5 ~y^2 + 3[/math]
If not, you can get help from the following free math tutoring YouTube channel "Math Tutoring by Dr. Liang"
https://www.youtube.com/channel/UCWvb3TYCbleZjfzz8HEDcQQ
Mathematics news on Phys.org
Hint: [math]x^4 +4 = x^4 + 4x^2 - 4x^2 + 4[/math]
-Dan
(up)
I don't see how that helps. $x^4+ 4$ obviously cannot be factored over the integer, or even over the real numbers.
As linear factors, yes. But:
[math]x^4 + 4 = x^4 + (4 x^2 - 4 x^2) + 4 = (x^4 + 4 x^2 + 4) - 4 x^2 = (x^2 + 2)^2 - 4 x^2 = (x^2 + 2 + 2 x)(x^2 + 2 - 2 x)[/math]
-Dan
Just to mention an alternative approach, $$x^4+4=0$$ has 4 imaginary solutions that form conjugate pairs.
The solutions are $$x=\pm 1\pm i$$
If we then put the conjugate pairs together, we get $$(x-(1+i))(x-(1-i))=x^2-2x+2$$ and $$(x-(-1+i))(x-(-1-i))=x^2+2x+2$$ just like topsquark found.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
