MHB Can you find the length of ON using Pythagoras and similarity?
  • Thread starter Thread starter alextrainer
    Triangle
The discussion focuses on calculating the length of segment ON using the properties of right triangles and similarity. The Pythagorean theorem is applied to find the hypotenuse of a smaller triangle, resulting in a length of approximately 46.65. By establishing the similarity between the larger and smaller triangles, a proportion is set up to determine the length of ON, leading to a calculated value of 30. Additionally, the Pythagorean theorem is used again to find the length of segment OP, resulting in an expression involving the square root of 34. The discussion effectively demonstrates the application of geometric principles to solve for unknown lengths.
alextrainer
In attached file, I understand 50 is the base; no idea how to use the 24 height to calculate length of ON - must have to do with property of right triangles?
Mathematics news on Phys.org
These are, of course, right triangles so you can use the Pythagorean theorem To determine the length of the hypotenuse of the small triangle. Then, since the angles of the large and small triangles are the same, they are similar triangles. Corresponding parts of the two right triangles are proportional.
Thanks for the smaller triangle I get hypotenuse of 46.65. Then each leg and hypotenuse is multipled by a proportion?
So larger triangle would be 50 leg - no idea how to figure height or hypotenuse unless I multiple by 10/40 percent all the known lengths.
Let:
$$\overline{NO}=x$$
Then, by similarity, we may state:
$$\frac{x}{50}=\frac{24}{40}=\frac{3}{5}$$
Hence:
$$x=50\cdot\frac{3}{5}=10\cdot3=30$$
And then by Pythagoras:
$$\overline{OP}=\sqrt{30^2+50^2}=10\sqrt{3^2+5^2}=10\sqrt{34}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
