Can you help me find Eigenvectors for this matrix?
  • Thread starter Thread starter M55ikael
M55ikael
Hi! I have this frustrating equation I can't solve even though I have the answer.
I'm trying to make two Eigenvectors for my matrix. I have found λ1 and λ2, but I can't solve the resulting equations.
A = \begin{bmatrix} 2 & 1 \\ -\frac{1}{2} & 1 \end{bmatrix}
λ1= 3/2 + j/2 , λ2= 3/2 - j/2
\begin{bmatrix} 2 -(3/2 + j/2) & 1 \\ -\frac{1}{2} & 1 - (3/2 + j/2) \end{bmatrix} * E1 = 0
Attempt at solution:
E1
α(-1-j) + 2β = 0
-α + β(-1-j) = 0
E2
α(-1+j) + 2β = 0
-α + β(-1+j) = 0
I can't make any sense out of those equations though.
Answers should be
E1 = \begin{bmatrix} 2 \\ -1+j \end{bmatrix} * c
E2 = \begin{bmatrix} 2 \\ -1-j \end{bmatrix} * t
c and t are different from 0
This looks fine. Maybe you got fouled up in the arithmetic. The matrix can be simplified a bit, which will make the subsequent work easier.
\begin{bmatrix} 1/2 - i/2 & 1 \\ -1/2 & -1/2 - i/2 \end{bmatrix}
I'm using i for the imaginary unit...
This row reduces to
\begin{bmatrix} 1 & 1 + i \\ 0 & 0 \end{bmatrix}
The top row says that x1 = -(1 + i)x2, so an eigenvector is
\begin{bmatrix} -1 - i \\ 1 \end{bmatrix}
E1
α(-1-j) + 2β = 0
-α + β(-1-j) = 0
E2
α(-1+j) + 2β = 0
-α + β(-1+j) = 0
Answers should be
Thanks, I allways knew it was pretty simple. But it's so easy to get your pluses and minuses mixed up, I couldn't get it reduced properly.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
