Can you turn a skyscraper into a magnet?
  • B
  • Thread starter Sir John Galt
  • Tags
    Magnet
In summary, it is possible to create an electromagnetic field around a skyscraper if you run sufficient current through the structural members (ie interconnected column and beam network), however this will have many problems due to the high resistance at the joints where the beams are joined.
Sir John Galt
TL;DR Summary
Assistance with conceptualizing stupid question greatly appreciated.....
Curious to know if possible to create an electromagnetic field around a skyscraper if you run sufficient current through the structural members (ie interconnected column and beam network).
Thanks in advance to any takers...
Likes InkTide and Delta2
Welcome to PF.
AC or DC ?
Either way, every floor will need to be driven with a separate supply, so the columns are equipotentials.
There will be big problems due to high resistance at the joints where the beams are joined. Either the beam was painted to protect it from the weather, or it is now rusty.
It is conceptually possible, but not practical. Why might you want to do that ?
Likes russ_watters
Thanks Baluncore, and my apologies for delayed response.
It's primarily a conceptual question relating to magnetic fields and the effects of compression of this magnetic field.
Lets say I have a 150 ft skyscraper and am looking to apply a electromagnetic field that would ionize Nitrogen in the air, one of the byproducts being Tritium (for which the decay looks low energy). Normally cosmic radiation (low intensity high velocity) produces this substance in nature, but I'm curious if a lower frequency and high intensity would result in same (except more of it). Besides the possibility of creating this radioactive biproduct of the ionization, let's say the structure then undergoes a controlled demolition.
As the height of the building compresses, does the same occur with the magnetic fields frequency? Creating even more tritium? I wasn't sure if the potential energy of the field at a given height would be converted in that manner...
Wait, what? A chemical interaction (ionization) resulting in a nuclear change?!
But you're not doing that with a cosmic ray gamma. Or an electrostatic field. You're going to do it with a magnetic field?! Wow, that's one powerful magnetic field you've imagined.
I do not think that a controlled demolition is a problem that you need to worry about. An uncontrolled demolition is certain.
Likes DaveC426913
Building an implosion bomb to demolish a skyscraper is not going to be an easy way to make tritium. We already have too many nuclear weapons on Earth today.
Likes russ_watters and bob012345
FAQ: Can you turn a skyscraper into a magnet?
Can a skyscraper be turned into a magnet?
Technically, it is possible to turn a skyscraper into a magnet by using strong electromagnets. However, the process would be extremely expensive and impractical.
How would turning a skyscraper into a magnet affect its structure?
The process of turning a skyscraper into a magnet would require adding large electromagnets to the structure, which could potentially cause structural damage or instability. The added weight and force of the magnets could also affect the building's ability to withstand wind and other external forces.
What would be the purpose of turning a skyscraper into a magnet?
The main purpose of turning a skyscraper into a magnet would be to generate electricity. The movement of the building through Earth's magnetic field would create an electric current, which could be harnessed as a renewable energy source.
How strong would the magnetic field be if a skyscraper was turned into a magnet?
The strength of the magnetic field would depend on the size and strength of the electromagnets used. It is possible to create a very strong magnetic field, but it would require a significant amount of energy and could potentially interfere with nearby electronics.
Are there any real-life examples of skyscrapers being turned into magnets?
No, there are currently no examples of skyscrapers being turned into magnets. However, there have been proposals and experiments to harness the Earth's magnetic field for electricity generation, but none have been implemented on a large scale.
