Capacitance between ground and copper loop in the air
The discussion focuses on calculating the capacitance between a copper closed loop and the ground for an electromagnetic device measuring soil humidity. The loop is positioned 70 cm above the ground, with a diameter of 1 meter and a width of 3 cm. Initial calculations suggest a capacitance value of approximately 3 pF, but the author anticipates that refining the model could yield a more accurate range of 7-10 pF. The approach involves using Gauss's theorem and integrating the electric field over the height to determine capacitance. The author seeks feedback on the calculations and methodology.
LorDjidane
Hello there
I'm currently working on an EM device that should be able to measure the humidity in the ground. I cannot give too many details, but let's consider the following issue:
I have a copper closed loop in which I send some current to generate a magnetic field. But there are some EM 'parasites', making my measurements unaccurate.
First of all, I'd like to compute the capacitance existing between my closed loop and the ground (note that the loop is at h=70cm height from the ground plus it has a diameter of 1m and a width of 3cm).
Here are my computations. I think I went way too fast, but this was only to get a rough idea in 30s about the expected value.
(s stands for sigma, e for epsilon, S for surface; I'm sorry, i will write down the latex stuff later)
Ground => E = s/2e
Loop => Q = I\Deltat (an approximation of my loop as a wire)
Then, Gauss theorem: E = Q/Se (that's the epsilon of the wire; I don't know what surface to take, i assume this is the surface seen by the ground?)
Total field: E = s/2e + I\Deltat/Se
Then I integer over the height h, since \DeltaU = -\int{E}, over h.
And that leaves me with:
C = Q/U (this Q is the total charge in the system (ground + loop))
C = [(s_ground/S_ground) + I\Deltat] / [h{(s_ground/2e_ground) + I\Deltat/(S_wire*e_wire)}]
(damn this is horrible; i'll correct it)
With this very simple model, I obtain a capacitance value of 3pF. That seems correct, I will just have to correct it to get some more details (I expect the value to be more around 7-10 pF).
What do you think?
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
