Capacitance of concentric shells
  • Thread starter Thread starter kenneth1100
    Capacitance
The discussion centers on the capacitance of concentric shells and the relationship between voltage on different surfaces. It clarifies that the voltage on the surface of one shell is influenced by the charge distribution of the other shell. A participant initially misunderstood the potential difference, believing it varied between the surfaces of the larger and smaller shells. The conversation highlights the importance of recognizing that voltage is uniform across a shell's surface. Overall, the exchange aims to clarify concepts related to electric potential in concentric shell systems.
kenneth1100
for the part of Capacitance of concentric shells
why Va equals that?
why the voltage on the surface of a is affected by -Q/(4pi*epsilon*b),
which represents the voltage on the surface of b
these two voltage represents something at different position!
thank you
i forgot that V in a shell/sphere is the same as if it's on the surface
I thought the p.d. by the larger shell were different on the surface of the larger shell and on the surface on the smaller shell...
that's why i got trouble
anyway, thanks~
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
