Capacitor Behaviour: AC Voltage Source Response
  • Thread starter Thread starter ahmedbadr
    Capacitor
The discussion centers on the behavior of capacitors in response to an AC voltage source. It confirms that during the positive half-cycle, the capacitor charges as the source voltage increases and discharges as it decreases. The concept of a clamper circuit is explained, highlighting that the capacitor charges to the peak voltage during the positive cycle and retains this charge, preventing discharge back into the source due to the diode's unidirectional nature. The difference between peak voltage and peak-to-peak voltage is clarified, with peak-to-peak being twice the peak value. Overall, the capacitor's ability to hold the peak voltage results in a modified output voltage in the circuit.
ahmedbadr
my question is about capacitor response to ac voltage source .
if we have circuit consistst of ac voltage source and a capacitor .so the variation of voltage across capacitor versus time will be as shown in the attached drawing.
and from this drawing i see that during the postive half wave ,as source voltage increasing ,voltage across capacitor also increasing (charging) and when source voltage decreasing to zero ,voltage across capacitor also decreasing (discharging).is my explanation about this is right??
my next question if this concept is right so why clamper circuit it shows that during positve half cycle when diode is short cicuit the cpacitor is charged to the peak voltage ?
we can see that in the link below
http://www.visionics.ee/curriculum/Experiments/Clamper/Clamper1.html
i hope u get my question
for clarification i mean if this explanation is right so the capacitor will be charged then discharged during the positive half cycle??so how it will only be charged to the peak voltage
Are you wondering why it is charged to peak instead of what? Peak x 2?
In the attached diagrams, during the first negative half cycle (ie like the bottom diagram), the capacitor voltage will follow the input voltage until the voltage starts to drop. The capacitor cannot discharge back into the supply because the diode cannot conduct backwards.
So, the capacitor holds the peak voltage of the supply.
The capacitor has no way of losing this charge, so it now appears in series with the source voltage.
See attached diagrams. The box on the left is a transformer giving 20 volts peak to peak, or 10 volts peak. Assume perfect diodes.
In the first one, the capacitor is charged to 10 volts and the input voltage is rising to a peak of +10 volts, so the output is +20 volts.
In the second one, the capacitor is still charged to 10 volts, but the input voltage is 10 volts negative, so the two cancel out and the output is zero volts.
So an input that was varying from +10 volts to -10 volts is now varying from +20 volts to zero volts. This is what a clamp circuit does.
thx for ur reply but still what peak to peak means and what's difference between peak to peak vlaue and peak value
A sinusoidal voltage as a function of time is written like this:
V(t) = A sin(wt)
Where A is the amplitude, and omega "w" is the angular frequency in radians per second.
The value A is called the peak amplitude. The peak-to-peak amplitude is 2A, because it is the difference between the positive peaks at A and the negative peaks at -A.
A - (-A) = 2A
Does that clear it up for you?
See attached picture.
thank u all for your reply
