Capacitor Comparisons: Quality Control, Testing, and Brand Names
The discussion focuses on the differences in capacitors, particularly regarding quality control, testing specifications like low ESR, and brand names. Participants debate the value of purchasing a $30 1.5 farad capacitor versus a $170 1 farad capacitor, highlighting the importance of application-specific requirements. One user emphasizes the need for a capacitor with a discharging/charging rate of less than one second for a design project. The conversation also touches on how the effective resistance and other specifications may vary in relevance depending on the intended use. Understanding these factors is crucial for making informed purchasing decisions in capacitor selection.
foahtein
Can anyone tell me the difference in capacitors. Such as the quality control in producing it, the testings, the specs (low esr), brand names, and if its worth buying a 30 dollars 1.5 farad capacitor v.s. a 170 dollars 1 farad capacitor.
thanks
http://www.uoguelph.ca/~antoon/gadgets/caps/caps.html" , they got a complete info on capacitors.
Let me guess foahtein, you're into car audio right?
thanks for the information, and averagesupernova, I'm not into car audio. I know that majority of the people who purchase cap's are into car audio, but I'm doing a design project that need a cap to have an actuation time of less than 1 sec.
Well, if you need the capacitor to have a discharging/charging rate of 1 sec, you need to evaluate:
Time Constant = R*C = Time to reach 63% of final value
Hmmmm. Actuation time meaning what? More info please. Depending on what you are doing, the ESR and other things might not mean a darn thing.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
