Capacitor. Find thickness of polystyrene
To find the thickness of a 490 pF capacitor with 19 cm radius plates insulated with polystyrene, the formula d = (ε_0 * Area * K) / C was used. The area of the plates was calculated as approximately 0.1134 m², and the dielectric constant (K) was initially taken as 2.3. After calculations, the thickness was found to be 4.71 mm, but this was incorrect due to the wrong K value. The correct dielectric constant for polystyrene is 2.6, which led to the realization of the error.
owtu
A 490 pF capacitor consists of two 19 cm -radius circular plates, insulated with polystyrene
Find the thickness of the polystyrene.
I converted 490 pF to F
4.90 * 10^-10 F
I converted 19 cm to meters
.19 m
and found the area of the plate
∏r^2 = ∏(.19)^2 = .1134 m^2
K of polystyrene = 2.3, so now just plug everything into my equation
d = ((2.3) * (8.854*10^-12) * (.1134)) / (4.9 * 10^-10)
d = .00471 m
I want my answer in mm with two significant figures
d = 4.7 mm
mastering physics tells me this is the wrong answer, where did I go wrong?
never mind, I found it. the value for K was 2.6 not 2.3, I was mistaken
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
