Capacitor RC Value - Charging/Discharging Explained
A capacitor in series with a resistor charges and discharges according to the RC time constant, with significant changes occurring at intervals of RC. After 5RC, the voltage across the capacitor will be very close to its final value, reaching less than 1% of the original voltage during discharge. The voltage decay follows a predictable pattern, with approximately 36.79% remaining after 1RC and only 0.67% after 5RC. This behavior applies equally to both charging and discharging processes. Understanding these principles is crucial for accurate circuit design and analysis.
ramonegumpert
Dear Experts,
I charged a capacitor that is in series with a resistor using a DC power source.
In practice, does a capacitor charge/discharge as per the calculated RC based on formula?
For example, does the capacitor really fully charge / discharge at 5RC?
Sincerely
Ramone
Yes and Yes. If you wait 5RC, the voltage across the capacitor will be very close to its final value.
The really strict answer is no, although as Corneo said, the value will be very close after 5RC. This applies to charge and discharge equally, but for the moment, let's think about discharging.
When a capacitor is discharging into a resistor, the voltage will decay as follows:
After 1RC the voltage will be 36.79% of the original value.
After 2RC the voltage will be 13.53% of the original value.
After 3RC the voltage will be 4.98% of the original value.
After 4RC the voltage will be 1.83% of the original value.
After 5RC the voltage will be 0.67% of the original value.
After 6RC the voltage will be 0.25% of the original value.
This really goes on forever, but note that by 5RC the voltage is below 1% of its starting point.
Similarly on charging, 5RC takes you to within less than 1% of the final (or more correctly asymptotic) value.
To add to Adjusters explanation, here's a graphic look at the charge/discharge curve.
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html"
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
