Capacitors and Dialectric Constant
The discussion revolves around calculating the time constants for two different configurations of identical capacitors connected with a resistor. The first circuit has a time constant of 0.67 seconds, and participants emphasize the importance of determining the total capacitance in each arrangement to find the time constant. The equivalent capacitance for the first circuit is identified as C, while the second circuit requires calculating the combined capacitance of capacitors in parallel and series. The ratio of the time constants is directly linked to the ratio of the equivalent capacitances. Clarification on the calculations and understanding of capacitor combinations is sought to resolve confusion.
kris24tf
Capacitors, Hard Problem
Four identical capacitors are connected with a resistor in two different ways. When they are connected as in part a of the drawing, the time constant to charge up this circuit is 0.67 s. What is the time constant when they are connected with the same resistor as in part b?
The pictures included are http://edugen.wiley.com/edugen/courses/crs1000/art/qb/6e/ch20p_99.gif
I really have no idea what I'm doing here. My work is as follows:
T=RC
Ta=RCa, Tb=RCb
Ca=Cs1+Cs2
1/Cs=1/C+1/C
1/2/C=1/2C=2C
1/Cb=1/Cp+1/C
Cb=1/(1/Cp+1/C)
Cp=C+C=2C
Cb=1/(3/2C)=s/3C
Ta=R(2)(C)
Tb=R(2/3)(C)
Tb/Ta=R(2)(C)/R(2/3)(C)
Tb=3Ta
If anyone could help me with what I did wrong/what I need to fix, I'd appreciate it
I didn't work through your equations, but basically you need to calculate the total capacitance in each situation to determine the RC time constant.
For the first circuit, the total combination of capacitance is C, right? Each leg is half of C, and the two parallel C/2 legs together gives you back a whole C, right? So the time constant for the first circuit is RC.
You need to then calculate the total combination of capacitance for the second circuit. The two caps in parallel are easy -- what is the combination of the two C caps in parallel? And then you end up with 3 caps in series -- the combo of the two parallel caps, plus the two C caps. What is the equation for combining caps in series? Just combine the equivalent capacitance from the two parallel C caps and the other two series C caps, and you will get an equivalent total capacitance. That will give you the relative time constant compared to the original RC from the first circuit. Makes sense?
I'm still confused. I tried working through what you said but I don't come up with anything...
You've got parts of it right in the work that you showed.
What is the equivalent capacitance of the caps in the first circuit arrangement? (parallel combo of two series C)
What is the equivalent capacitance of the caps in the second circuit arrangement? (two parallel C then in series with two other C)
What is the ratio between these two equivalent capacitance values? That will be the ratio of the time constants...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
