Car Braking Distance: Calculating Distance to Avoid Collision
  • Thread starter Thread starter alex81388
    Braking Car
The discussion focuses on calculating the braking distance required for a faster car to avoid colliding with a slower car. Initially, the calculation yielded an incorrect distance of 257.8 meters, as it did not account for the distance the slower car traveled during the braking time. By considering the slower car's movement, the correct distance was determined to be 195.313 meters. The importance of drawing a diagram and understanding frames of reference was highlighted as helpful in solving the problem. Ultimately, the adjustment for the slower car's distance was crucial for arriving at the accurate answer.
alex81388
A certain automobile can decelerate at |a1| = 1.6 m/s2. Traveling at a constant v1 = 29 m/s, this car comes up behind a car traveling at a constant v2 = 4 m/s. How close to the slower car can the driver of the faster car come before applying his brakes and still avoid a collision?
V(final)^2 - V(initial)^2 = 2a(X(final)-X(initial))
X = X(initial) + V[initial]*t + .5(a)(t^2)
V[final] = V[initial] + at
First thing we need is to solve for the time needed to for the application of the braking system:
4 = 29 + (-1.6)(t)
t = 15.625
x = 0 + (29)(15.625) + .5(-1.6)(15.625^2)
x=257.8
So I decided the answer was 257.8 meters. This however is not correct. What am I doing wrong?
Thanks in advance for all your help!
Have you drawn a diagram yet? I think if you did, it would be very helpful.
Also, have you covered frames of reference?
I have not yet covered frames of reference. I tried drawing a diagram and the thought process still makes sense to me.
Actually your diagram did help. Very good Advice.
I realized that as my chasing car was decelerating to the forward car's speed, the forward car was in fact still moving so its extra distance had to be accounted for (or in fact, discounted for).
My answer of 257.813 - 62.5 [the distance the forward car went in 15.625 seconds] = 195.313meters and is correct.
Thank you very much for your help :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
