Car door shutting at a certain acceleration
  • Thread starter Thread starter Mastablade
    Acceleration Car
The discussion revolves around calculating the time it takes for a car door to close when the car accelerates at 3 m/sec². The door is modeled as a uniform square sheet of steel with specific dimensions and mass, and the solution involves calculating torque and angular acceleration. The initial calculations yield a torque of 48 and an angular acceleration of 3.75. However, there are questions raised about the use of moment of inertia and the physical principles applied in the calculations. The thread highlights a need for clarification on the formulas used and suggests reviewing relevant physics concepts.
Mastablade
A car has its door open at 90 degrees. The door is considered a uniform square sheet of steel of side .8 m and mass 20kg. The hinges on the door are frictionless. At time t = 0 the car accelerates with constant acceleration a = 3 m/sec^2. How long does it take the door to close?
Torque = Mass * radius * acceleration
acceleration = radius * alpha
Torque = Mass * radius^2 * alpha
T = 20 (Mass) * (.8)(Radius) * 3 (Acceleration)
T = 48
alpha = 48(Torque) / (.8^2)(Radius) * (20)(Mass) = 3.75
Now that I have angular acceleration, I need only to integrate twice to find the time.
omega = 3.75t
theta = 3.75t^2 / 2 theta = 90 degrees or pi/2 in radians so,
pi/2 = 3.75t^2 / 2 pi/3.75 = t^2 t = sqr root (pi/3.75)
t = .92 seconds
Hopefully these are the correct formulas, but I could use someone to check if these are right. Thanks in advance.
Hi Mastablade! :smile:
Sorry, I don't understand any of this. :redface:
What is the torque ?
Why are you not using moment of inertia ?
What physical principle are you using ?
Go back to your book, and read the chapter again. :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
