Car is traveling at a speed, what speed will a truck have the same momentum?
A car with a mass of 964.0 kg traveling at 63.3 km/hr has a momentum of 16,947.12 kg·m/s. To find the speed at which a truck weighing 3,530.7 kg would have the same momentum, the equation p = mv is used. Solving for the truck's speed yields approximately 4.79 m/s. This speed converts to about 17.25 km/hr. Thus, the truck must travel at 17.25 km/hr to match the car's momentum.
IDKPhysics101
A car with a mass of 964.0 kg is traveling at a speed of 63.3 km/hr. At what speed (in km/hr) will a 3530.7 kg truck have the same amount of momentum as the car?
First start by asking yourself what is the definition of linear momentum and hence what is the momentum of the car?
car
speed=63.3km/hr=17.58m/s
p=964*17.58
p=16947.12
truck
p=mv
16947.12=3530.7*V
V=4.79m/s??
IDKPhysics101 said:
car
p=964*17.58
p=16947.12
truck
p=mv
16947.12=3530.7*V
V=4.79m/s??
Yes, that should be correct.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
