Car passing a truck — calculating the relative motions
The discussion revolves around calculating the relative motion of a car and a truck during a passing maneuver. Participants emphasize the importance of defining variables and using correct equations to determine distances and times accurately. The car accelerates from 20 m/s to 25 m/s, covering a distance of 62.5 m during this phase, while the truck moves 50 m in the same time frame. The car is initially 37.5 m behind the truck, and participants discuss methods to calculate when the car will catch up, suggesting both trial and error and algebraic manipulation of motion equations. The conversation highlights the need for precision in calculations and understanding the underlying physics principles.
rssvn
Car drives a straight road at 20m/s, a truck is driving at 18m/s infront of the car. When the car is 50 m behind the truck, it starts to pass the truck with constant acceleration of 1.8m/s^2 until it hits the speedlimit of 25m/s, after that the car continues driving with the speed of 25m/s.
a) How far has the car gone during the acceleration?
b) How far did the car get when the front of the car was next to the front of the truck, start from the beginning of the acceleratoion.
vf=vi+at , vf^2=vo^2+2a(xf-xo)
The question was translated from finnish so apologies if everything doesn't make sense:) and please do tell if the equations are wrong.
Welcome to PhysicsForums. :smile:
Can you make a sketch of the position of each vehicle versus time and upload it? That would help us to get you started on the problem. Use the "Attach files" link below the Edit window to upload a PDF or JPEG copy of your sketch. We need to see your best efforts to start working the problem before we can offer tutorial help. Thanks.
The question is clear and makes sense.
The equations look ok, but equations can only really be judged when all the variables are defined and all the assumptions stated.
The test will be in how you apply them. We look forward to seeing that.
Here are 2 quick graphs i made, please let me know if they are not sufficient :)
I'm not sure those help you very much. The car accelerates for a time, so its distance vs time graph should be curved.
In any case, have you made any progress with the calculations?
Let's start with this piece:
"Car drives a straight road at 20m/s ... constant acceleration of 1.8m/s^2 until it hits the speedlimit of 25m/s."
How long does that take and how far has the car travelled?
2.8 s to reach 25m/s and 90.4m? and thank you all for helping! :)
2.8s, yes (though I wouid keep a bit more precision at this stage), but how do you get 90.4m?
I meant 70.4 :) i added 1.8 m/s to the initial 20m/s for 2.8 times
  • Skeptical
Likes PeroK
rssvn said:
I meant 70.4
Still too much. What is the average speed during the constant acceleration?
I hope what you mean is that you added 1.8m/s2 for time t to the initial 20m/s to get to 25m/s.
Yes, sorry didnt know how to write it correctly :) and average speed 22.5m/s
According to my calculator ##5/1.8 = 2.777 \dots##, so I'd use ##t = \frac{25}{9} s##.
Yes, 22.5m/s average for 2.78s. So what distance is covered?
how did you get 25/9?
62.55 m
rssvn said:
how did you get 25/9?62.55 m
Yes. But I strongly encourage you to resist plugging in numbers until the end for any given answer. It has many advantages.
E.g. if you had written ##v_f=v_i+at## and ##s=(v_i+v_f)t/2## you would have arrived at ##s=\frac{v_f^2-v_i^2}{2a}=62.5m## exactly.
Next, where is the car in relation to the truck at the end of the acceleration?
Ah, i had been counting xo as 50m in the second equation.
the car is at the rear of the truck?
There's no reason to suppose that.
You know what the relative positions were at the start of the acceleration, and you know how far the car went during the acceleration and how long that took. So how do you work out the relative position at the end of the acceleration?
##5/1.8 = 25/9##
So, I can check your answer for distance:
$$(\frac {25} 9 s) \times (22.5 m/s) = (\frac {25} 9) \times (\frac {45} 2)m = 25 \times (\frac 5 2)m = \frac{125}{2}m = 62.5m$$ With no rounding errors!
Perhaps you don't get taught this sort of thing in schools anymore? In any case, if you put ##22.5 \times 5 / 1.8## into a calculator you'll get an exact answer.
Try using the ##25/9 \ s## or ##5/1.8 \ s## to calculate where the truck is when the car stops accelerating. Is that better than using ##2.78s##?
if the truck went 50m in 2.78s and the car went 62.55m it must be still behind the truck
PeroK said:
##5/1.8 = 25/9##
yes, they have been taught but i had completely forgotten about it, it's been a while since I've been around with math this much :)
Likes PeroK
So, what's the next part of the problem?
And it should be exactly ##62.5m##!
Right, but how far behind? And given their relative velocities, how long will it take for car to get abreast of the truck?
Likes rssvn
it's 37.5m behind the truck, but I am sorry to say that i need another tip, i don't understand how can i figure out the exact time when the car is abreast the truck.
There are three ways to do it:
1) Intuitively.
2) Using equations of motion
3) By trial and error
For 3) it's like playing a computer game. You move forward 1 second at a time and note the position of the truck and the car and eventually the car must catch the truck.
The point of 3) is that it might give you some idea of which equations are involved. To get you started
t = 0: car = 0m, truck = 37.5m
t = 1: car = 25m, truck = 55.5m
1) Intuitively.
ah yes 125m! i tried to calculate it with 3) but for some reason i was thinking it was a good idea to use the 2.78s time scale to find the right answer and not the 1s which is much much simpler. Can you tell me what would the equations be so solve it? :)
What you are doing in that trial and error example is plotting the position of the car as: $$x_{car} = 0 + v_{car}t = (25m/s)t$$ and the position of the truck $$x_{truck} = 37.5m + v_{truck}t = 37.5m + (18m/s) t$$ where ##t## is the time from the end of the car's acceleration phase.
The equation you need to solve is $$x_{car} = x_{truck}$$
Likes rssvn
I get it now!
And the answers were a) 62.5 and b) 187.5 (125m plus the initial 62.5 that it went during the acceleration)
rssvn said:
I get it now!
Except, I don't get ##125m## for the second phase. At ##t = 5s## I get: ##x_{car} = 125m## and ##x_{truck} = 127.5m##. The car still has a little bit of catching up to do.
Ah, youre right, maybe I'm trying to rush the answer and make silly mistakes like that on the way, t = 5.35s seems to be pretty close, i tried it by trial and error. 5.35s and 133.75m
Trial and error is okay, but you still need to find the right answer. It's better to use the equation now that you understand what's going on.
What equation should i use if i don't use the trial and error, isn't the equation you gave Xcar = Xtruck basically using trial and error?
  • #31
No, because you have:
The position of the car is: $$x_{car} = 0 + v_{car}t = (25m/s)t$$ and the position of the truck $$x_{truck} = 37.5m + v_{truck}t = 37.5m + (18m/s) t$$ where ##t## is the time from the end of the car's acceleration phase.
And, that's not a hard equation! You need to solve for ##t##, of course.
  • #32
I'm sorry if I am not understanding, but how can i figure out the t if not by trial and error
  • #33
By using ... mathematics!
  • #34
This is standard algebraic manipulation.
Look at @PeroK's equations:
PeroK said:
$$x_{car} = (25m/s)t$$ $$x_{truck} = 37.5m + (18m/s) t$$ $$x_{car} = x_{truck}$$
You can use the third equation to collapse the first two into a single equation involving neither xcar nor xtruck. Can you see how to do that?
This leaves you with an equation in which the only unknown is t.
If you gather all the terms involving t onto one side of the equation and all the terms not involving t onto the other side you can find the value of t.
Likes Lnewqban
  • #35
Sorry for taking so long to answer, i understand now, (25m/s)t=37.5m+(18m/s)t -> 25t-18t=37.5m -> 7t=37.5m -> 5.36. Thank you @PeroK and @haruspex for bearing with me, i do appreciate it :)
  • #36
Perhaps it's worth just summarising this.
There was a quick way to solve the problem, which is to take the difference in speeds of the car and the truck and the distance between them. In this case, the distance separating them was ##37.5m## and the car was traveling ##7m/s## faster than the truck. The time at which the car catches the truck is simply: $$t = \frac{37.5m}{7 m/s} = 5.36s$$
The other approach is to draw a graph of position against time of both vehicles. The point of intersection on the graph is the time at which the car catches the truck. This is related to the equations of motion as: $$x_{car} = (25m/s) t$$ and $$x_{truck} = 37.5m + (18m/s)t$$ represent straight lines on the graph and the point of intersection is the point where $$(25m/s) t = 37.5m + (18m/s)t$$ In any case, the important thing is to understand how these equations and graphs relate to the real motion and position of the vehicles.
  • #37
Don't we need to know the length of the truck ? Since 50m behind truck means 50m behind rear of truck. Still have further displacement (if not negligible) of truck length. See other "Car passing Truck" thread below.
  • #38
Not necessarily. If you are 50m behind in a race, that would be measured from front of vehicle to front of vehicle.
Likes neilparker62
  • #39
Relative velocity problem. Car traveling with initial velocity of 2m/s 50m behind "stationary" truck. Accelerates at 1.8 m/s/s till reaching 7m/s and maintains this until level with the truck. Area under graph up to t1 is 12.5m and 37.5m between t1 and t2. Simply add 18t for the actual displacement of car at t1 and t2 respectively.
Relative Velocity vs Time graph:
https://www.desmos.com/calculator/rgbooatiss
Relative Displacement vs Time graph:
https://www.desmos.com/calculator/ophyml0qrd
  • #40
True but I think there is a problem with the ambiguity. Initially you think something is not quite right but you can't exactly place it!
