Carnot Heat Engine: Solve for Heat Expelled to Cold Res.
A Carnot engine operates between a hot reservoir at 63°C and a cold reservoir at -14°C, absorbing 590 J of heat. The temperatures are converted to Kelvin, resulting in T_H = 336 K and T_C = 259 K. The heat expelled to the cold reservoir is calculated using the ratio Q_H/Q_C = T_H/T_C, leading to Q_C = 504 J initially. However, the correct cold reservoir temperature should be -14°C, which is 259 K, not 287 K. This oversight in temperature conversion resulted in an incorrect calculation of the heat expelled.
tehjojo
Consider a Carnot engine that operates between a hot reservoir at 63°C and a cold reservoir at -14°C. In running 25 minutes, this engine absorbs 590 J of heat from the hot reservoir.
How much heat does it expel to the cold reservoir?
Q_H/Q_C = T_H/T_C
T_H = 336k
T_C = 287k
Q_H/Q_C = T_H/T_C \longrightarrow 590/Q_C = 336/287
Solving for Q_C I get 504 J, however, this is not the correct answer. What am I missing?
Are you sure Tc= 287 K? The cold reservoir is at -14 C
Wow. It happened that on the site my homework is on, the negative sign and the number were on different lines, so I totally missed it. Thank you very much.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
