MHB Carothers' Definitions: Neighborhoods, Open Sets, and Open Balls
The discussion centers on N. L. Carothers' definitions of open sets, neighborhoods, and open balls in his book "Real Analysis." A key point raised is the relationship between these concepts, particularly how an open set can be defined in terms of neighborhoods. It is clarified that if a set U contains a neighborhood N of a point x, which in turn contains an open ball Bε(x), then Bε(x) must also be a subset of U. The distinction is made that while every open set containing x is a neighborhood of x, not all neighborhoods are open sets. This nuanced understanding of the definitions is essential for grasping the foundational concepts in real analysis.
Math Amateur
MHB
The Definition of a Neighborhood and the Definition of an Open Set ... Carothers, Chapters 3 & 4 ...
I am reading N. L. Carothers' book: "Real Analysis". ... ...
I am focused on Chapter 3: Metrics and Norms and Chapter 4: Open Sets and Closed Sets ... ...
I need help with an aspect of Carothers' definitions of open balls, neighborhoods and open sets ...Now ... on page 45 Carothers defines an open ball as follows:
View attachment 9213Then ... on page 46 Carothers defines a neighborhood as follows:
And then ... on page 51 Carothers defines an open set as follows:
Now my question is as follows:
When Carothers re-words his definition of an open set he says the following:
" ... ... In other words, $$U$$ is an open set if, given $$x \in U$$, there is some $$\epsilon \gt 0$$ such that $$B_\epsilon (x) \subset U $$ ... ... "
... BUT ... in order to stay exactly true to his definition of neighborhood shouldn't Carothers write something like ..." ... ... In other words, $$U$$ is an open set if, for each $$x \in U$$, $$U$$ contains a neighborhood $$N$$ of $$x$$ such that $$N$$ contains an open ball $$B_\epsilon (x)$$ ... ..."Can someone lease explain how, given his definition of neighborhood he arrives at the statement ...
" ... ... In other words, $$U$$ is an open set if, given $$x \in U$$, there is some $$\epsilon \gt 0$$ such that $$B_\epsilon (x) \subset U$$ ... ... "
Reflection ... maybe we can regard $$B_\epsilon (x)$$ as a neighborhood contained in U since $$B_{ \frac{ \epsilon }{ 2} }(x)$$ $$\subset$$ $$B_\epsilon (x)$$ ... is that correct?But then why doesn't Carothers just define a neighborhood of $$x$$ as an open ball about $$x$$ ... rather than a set containing an open ball about $$x$$?=========================================================================================
Hope someone can clarify ...
Peter
Re: The Definition of a Neighborhood and the Definition of an Open Set ... Carothers, Chapters 3 & 4
If $$U$$ contains a neighborhood $$N$$ of $$x$$ such that $$N$$ contains an open ball $$B_\epsilon (x)$$ then $x\in B_\epsilon (x) \subseteq N \subseteq U$, so it is certainly true that $B_\epsilon (x) \subseteq U$. Conversely, $B_\epsilon (x)$ is a neighbourhood of $x$, so if $B_\epsilon (x) \subseteq U$ then we can take $N = B_\epsilon (x)$. It will then be true that "$$U$$ contains a neighborhood $$N$$ of $$x$$ such that $$N$$ contains an open ball $$B_\epsilon (x)$$".
Notice that an open set containing $x$ is a neighbourhood of $x$. But a neighbourhood of $x$ need not be an open set contining $x$ (because a neighbourhood does not have to be open).
Thanks for the help Opalg ...
Peter
We all know the definition of n-dimensional topological manifold uses open sets and homeomorphisms onto the image as open set in ##\mathbb R^n##. It should be possible to reformulate the definition of n-dimensional topological manifold using closed sets on the manifold's topology and on ##\mathbb R^n## ? I'm positive for this. Perhaps the definition of smooth manifold would be problematic, though.
