Cartesian and polar coordinate in Simple pendulum, Euler-Lagrange
The discussion focuses on the application of the Euler-Lagrange equation to a simple pendulum using both Cartesian and polar coordinates. It highlights that substituting different coordinate systems simultaneously leads to incorrect results, as the pendulum has only one degree of freedom. The Lagrangian must be expressed in terms of a single independent variable, either θ, x, or y, to maintain consistency. The conversation emphasizes the importance of adhering to the constraints of degrees of freedom when applying Lagrangian mechanics. Ultimately, the pendulum's dynamics can only be accurately described using one coordinate system at a time.
Father_Ing
Find the equation of motion of a simple pendulum.
L = T-V
$$L = \frac {mv^2}{2} - mgy$$
It is clear that ##\dot{x}=\dot{\theta}L## and ##y=-Lcos \theta##. After substituting these two equations to Lagrange equation, we will get the answer by simply using this equation: $$\frac {d} {dt} \frac {∂L}{∂\dot{\theta}} - \frac {∂L}{∂\theta }= 0$$
But, What if we only substitute ##\dot{x}=\dot{\theta}L## to the Lagrange?
$$L = \frac {mL^2 \dot{\theta}^2}{2} - mgy$$
Then:
$$\frac {d} {dt} \frac {∂L}{∂\dot{\theta}} - \frac {∂L}{∂\theta }= 0$$ $$\frac {d} {dt} \frac {∂L}{∂\dot{y}} - \frac {∂L}{∂y }= 0$$
So, We get : $$mL^2 \ddot{\theta} = 0$$
But, this answer definitely does not make any sense. Is this caused by using two different types of coordinate system at the same time?
If yes, then why is this prohibited?
The pendulum has only one degree of freedom (independent variable), which is either ##\theta## or ##x## or ##y##.
What you have described is a different system where ##y## and ##\theta## are separate degrees of freedom. PS Although it may not make much physical sense, as there is no KE associated with movement in the ##y## direction.
PeroK said:
The pendulum has only one degree of freedom (independent variable), which is either θ or x or y.
But, all three of them depends on time (because if it is not, I don't think we can differentiate it with respect to time).
If your system has ##n## degrees of freedom, then the Euler-Lagrange equations in the form you quote (known as the "second kind") require that the Lagrangian is expressed using ##n## independent generalised coordinates. Your pendulum has only one degree of freedom, so you must express ##L## in terms of either ##\theta##, or ##y##, or ##x##, or some other coordinate, but not any more than one of them!
If the number of coordinates ##\tilde{n}## exceeds the number of degrees of freedom ##n##, then given ##\tilde{n}-n## holonomic constraint equations expressing the dependencies of these coordinates on each other you can:
1. use the constraint equations to eliminate ##\tilde{n} - n## of these coordinates and get an independent set.
2. or use Lagrange multipliers and Lagrange's equations of the "first kind".
Likes vanhees71 and PeroK
I can't see the relevance of that. A simple pendulum has one degree of freedom. Full stop.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
