I Cartesian velocity and generalized velocity
The discussion revolves around a query regarding a specific notation in "A Student's Guide to Lagrangians and Hamiltonians" by Patrick Hamill, specifically whether to use ##\delta_{kj}## instead of ##\delta_{ij}## in the context of generalized velocity. Participants agree that the notation should indeed be ##\delta_{kj}##. The conversation is brief, with a focus on clarifying this point in the text. The consensus reinforces the importance of accurate notation in understanding the material. Overall, the discussion emphasizes the need for precision in mathematical expressions within the book.
beowulf.geata
Hi,
I'm reading A Student's Guide to Lagrangians and Hamiltonians by Patrick Hamill and, in the following section on generalized velocity, I'm wondering if we should have ##\delta_{kj}## rather than ##\delta_{ij}##?
Many thanks.
beowulf.geata said:
Hi,
Looks like it.
PeroK said:
Looks like it.
Many thanks!
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
