CCMRR Common to Common Mode Rejection Ratio
  • Thread starter Thread starter icthyus
    Mode Ratio
Common-to-common Mode Rejection Ratio (CCMRR) is a parameter relevant to differential output amplifiers, indicating how much common mode signal at the input translates to the output. The discussion highlights confusion surrounding CCMRR, Differential Common Mode Rejection Ratio (DCMRR), and Common Differential Mode Rejection Ratio (CDMRR), particularly in the context of twisted differential pair cabling and jacks. Clear definitions and examples for these terms are lacking, prompting a request for technical explanations and testing methods. Resources provided include links to documents that elaborate on differential signaling and practical measurements of these ratios. Understanding these concepts is crucial for predicting signal integrity in differential signaling applications.
icthyus
I understand Common-mode rejection ratio. I do not however understand common-to-common Mode rejection or common to differential mode rejection or differential to common mode rejection. I am looking at this in regard to twisted differential pair cabling, specifically jacks. I can find the term here and there but no clear definitions or examples.
CCMRR is basically the same as CMRR but it's for differential output amplifiers. This parameter let's you predict how much of the common mode signal at the input will be passed to the common mode signal at the output. For a description of differential output signaling you can review this.
http://www.latticesemi.com/lit/docs/appnotes/pac/an6019.pdf
Thanks for the start. I am lookin for a technical answer though. I understand differential signaling and all. I just don't understand CCMRR the difference between DCMRR and CDMRR. Maybe someone could explain how you test for it. Any help would be appreciated.
Here's a site where someone plays with balanced line drivers and makes measurments of CCMRR, CDMRR and DCMRR. He shows the formulas relating input and output common mode signals.
http://sound.westhost.com/balance.htm"
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
