Centre of an Algebra .... and Central Algebras ....
  • MHB
  • Thread starter Math Amateur
  • Tags
    Algebra
In summary, Bresar discusses the definition of the center of a unital algebra, and how this definition is not based on an axiom. He explains that the center of a unital algebra is simply the set of all scalar multiples of unity.
Math Amateur
MHB
3,998
48
I am reading Matej Bresar's book, "Introduction to Noncommutative Algebra" and am currently focussed on Chapter 1: Finite Dimensional Division Algebras ... ...
I need help with some remarks of Bresar on the centre of an algebra ...
Commencing a section on Central Algebras, Bresar writes the following:https://www.physicsforums.com/attachments/6243
In the above text we read the following:
" ... The center of a unital algebra obviously contains scalar multiples of unity ... ... "Now the center of a unital algebra \(\displaystyle A\) is defined as the set \(\displaystyle Z(A)\) such that
\(\displaystyle Z(A) = \{ c \in A \ | \ cx = xc \text{ for all x } \in A \} \)Now ... clearly \(\displaystyle 1 \in Z(A)\) since \(\displaystyle 1x = x1\) for all \(\displaystyle x\) ...
BUT ... why do elements like \(\displaystyle 3\) belong to \(\displaystyle Z(A)\) ... ?
That is ... how would we demonstrate that \(\displaystyle 3x = x3\) for all \(\displaystyle x \in A\) ... ?
Hope someone can help ...
Peter
Well, using the distributive properties and the fact that $x = x1$ for all $x$,
$$3x = x + x + x = x1 + x1 + x1 = x(1 + 1 + 1) = x3$$
More generally, one of the axioms for an algebra $A$ over a field $F$ says that $$\lambda(xy) = (\lambda x)y = x(\lambda y)$$ for all $\lambda\in F$ and $x,y\in A.$ It follows that $$\lambda x = \lambda(x1) = x(\lambda 1) = x\lambda.$$
Thanks Euge ...
Just wondering how you did this without using the axiom that Opalg refers to ... I think it is called "The Compatibility Axiom" ... ... namely ... ... for an algebra $A$ over a field $F$ says that $$\lambda(xy) = (\lambda x)y = x(\lambda y)$$ for all $\lambda\in F$ and $x,y\in A.$ ...
As Opalg says ... It follows that $$\lambda x = \lambda(x1) = x(\lambda 1) = x\lambda.$$
... but you don's appear to need it ... why?
Peter
Hi Opalg ... thanks for the help ...
But ... just need a further point clarified ...
You write:
" ... ... It follows that $$\lambda x = \lambda(x1) = x(\lambda 1) = x\lambda.$$ ..."
But in this statement \(\displaystyle 1 \in A\) ... that is we are dealing with \(\displaystyle 1_A\) ... ...
and your equation
uses the equality or equivalence \(\displaystyle \lambda 1_A = \lambda \)Now ... although it is clear from the axioms that apply that \(\displaystyle \lambda 1_F = \lambda\) ... ...... why is it the case that \(\displaystyle \lambda 1_A = \lambda\) ... what axiom
underpins this statement.
Can you help?
Peter
Peter said:
Thanks Euge ...
Peter
An algebra over a field is, in particular, a vector space of the field -- so the distributive properties hold. With that, the result follows immediately.
This is not an axiom, but a convention, as stated by Bresar just after his Definition 1.14. In the section of text that you reproduce above, he states "... we identify $F$ with $F\cdot 1$, and write $\lambda$ instead". The rest of the sentence is omitted, but presumably it says "... write $\lambda$ instead of $\lambda 1$".
Thanks to Opalg and Euge for considerable help on this issue ...
You posts were a real help ...
Peter
FAQ: Centre of an Algebra .... and Central Algebras ....
What is the definition of the Centre of an Algebra?
The Centre of an Algebra is the set of elements that commute with all other elements in the algebra. In other words, it is the set of elements that do not change when multiplied by any other element in the algebra.
How is the Centre of an Algebra related to the concept of a central element?
A central element is an element that commutes with all other elements in the algebra, making it a part of the Centre. However, not all elements in the Centre are necessarily central.
Can the Centre of an Algebra be empty?
Yes, it is possible for the Centre of an Algebra to be empty. This means that there are no elements that commute with all other elements in the algebra.
What is the significance of the Centre of an Algebra?
The Centre of an Algebra is important because it helps determine the structure and properties of the algebra. It also plays a crucial role in the classification of algebras and their representations.
How is the Centre of a Central Algebra different from the Centre of a non-Central Algebra?
A Central Algebra is an algebra where all elements are central, meaning they commute with each other. In this case, the Centre of the Algebra is the entire algebra. In contrast, the Centre of a non-Central Algebra would only consist of a subset of elements that commute with all other elements in the algebra.
