Centripetal Acceleration and Satellite Question
The discussion revolves around calculating the speed and orbital time of a satellite in circular orbit 600 km above Earth's surface, where the free-fall acceleration is 8.21 m/s². The initial calculations for speed using centripetal acceleration were incorrect due to a misunderstanding of the radius and unit conversions. The correct approach involves using the total radius of 7000 km (Earth's radius plus altitude) in the centripetal acceleration formula. The user also realized an error in calculating time, initially forgetting to convert kilometers to meters. Ultimately, the correct calculations resolved the issues, confirming that gravity provides the necessary centripetal force for the satellite's motion.
chihockey7
1. The astronaut orbiting the Earth in Figure P4.30 is preparing to dock with a Westar VI satellite. The satellite is in a circular orbit 600 km above the Earth's surface, where the free-fall acceleration is 8.21 m/s2. The radius of the Earth is 6400 km.
a) Determine the speed of the satellite. m/s
b) Determine the time required to complete one orbit around the Earth. min
2. Homework Equations [/b]
centripetal acceleration= v squared/ radius
distance*speed= time
3. The Attempt at a Solution [/b]
To solve for the speed I used 8.21 as the centripetal acceleration and made that equal to v squared/7000 and then solved for v.
8.21=v squared/7000
v= 239 m/s
I then took 14000*3.14 for the circumference of the orbit and multiplied that by 239 m/s for the total time to orbit and divided that by 60 to put the answer in minutes. I got 2919.94 minutes.
However, both answers are wrong. Can I not use the free fall acceleration for centripetal acceleration?
Welcome to PF,
Are you trying to claim that distance*speed = time? You might want to rethink that one...
Yes, you can, and you should, because gravity is what is providing the centripetal force that keeps the satellite moving in a circle. You might have a computation error. Can you post your calculations for part a?
for part a I used the equation centripetal acceleration= v^2/ radius
8.21= v^2/(6400+600)
57470=v^2
v= 239.73
what is wrong with this calculation?
Concerning finding the time. I completely forgot that t=distance/speed.
I just realized my problem. I did not do the simple unit conversions from km to m. Everything worked out fine. Thanks for all of your help!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
