Centripetal acceleration/ angular velocity question
The discussion revolves around calculating the angular speed required for a circular space station to simulate Earth's gravity for its occupants. The diameter of the station is given as 52.5 meters, leading to a radius of approximately 8.356 meters. The user initially calculated the linear speed using the formula for centripetal acceleration, arriving at a value of 9.0538 m/s. However, they later realized they mistakenly used the diameter instead of the radius in their calculations. This highlights the importance of careful attention to detail in physics problems.
carsonk152
This is my first post on here so let me know if I need to provide more info.
A proposed space station includes living quarters in a circular ring 52.5 m in diameter. At what angular speed should the ring rotate so the occupants feel that they have the same weight as they do on Earth?
r=c/2Pi
a(centripetal)= v2/r => v=sqrt( ac*r
Δ∅=s/r
r=52.5/2*Pi= 8.356
v= sqrt(9.81*8.356)=9.0538
Δ∅=9.0538/8.356=1.084 rad/sec
This was my first attempt at the problem but I was returned that the answer is wrong, any ideas on what I did?
Just kidding I realized I confused the diameter with the circumference, of course it's always the little things...
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
