Centripetal acceleration centrifuge
A centrifuge operates by rotating a container at high speeds, causing denser materials to settle at the bottom. The centripetal acceleration of the sample is 5.92 x 10^3 times gravity, and the radius of rotation is 6.37 cm. The calculation for velocity involves using the formula Ac = V^2/r, leading to a velocity of approximately 60.79 m/s. To convert the period to revolutions per minute (RPM), the relationship between period and frequency must be correctly applied. The final conversion from period to RPM requires careful attention to units to ensure accurate results.
pookisantoki
A centrifuge is a device in which a small container of material is rotated at a high speed on a circular path. Such a device is used in medical laboratories, for instance, to cause the more dense red blood cells to settle through the less dense blood serum and collect at the bottom of the container. Suppose the centripetal acceleration of the sample is 5.92 x 10^3 times as large as the acceleration due to gravity. How many revolutions per minute is the sample making, if it is located at a radius of 6.37 cm from the axis of rotation?
Acceleration due to gravity is 9.80 and I converted 6.37cm to .0637m.
So this is how I solved it: Ac=V^2/r so set it up where V^2=Ac*r=sqrt(9.80*5920)*.0637= 60.79160
Then V=(2pi*r)/T so T=(2pi*r)/V: (2pi*.0637)/60.79160=.006584
Is this right??
I didn't double check your numbers, but you solved for period and the question asks for rpm, just remember to do the appropriate conversion.
I'm not sure on how to go from period to RPM
Well period is seconds per revolution, while rpm is revolutions per minute. Recall 1/T=F, the frequency, which has units revolutions per second.
So would it be .006584*60=.39504??
No... check your units and make sure they come out alright. What you have is this:
.0065 \frac{\textrm{seconds}}{\textrm{revolution}} \times 60\frac{\textrm{seconds}}{\textrm{minute}} = .395 \frac{\textrm{seconds}^2}{\textrm{revolution minute}}
Which is obviously not right. Remember where you want to go, which is revolutions/minute.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
