Centripetal acceleration problem
The discussion revolves around calculating the centripetal acceleration of a turbine's blades in a hydroelectric power station, given its diameter and rotation frequency. Users attempt to apply the formula a=4π²Rn² but encounter discrepancies in their answers, questioning the correctness of the provided solution. There is confusion regarding the conversion of rotational frequency from RPM to RPS and the calculation of the period for one revolution. Participants clarify that the period is the inverse of frequency, leading to further discussions about the formulas used for acceleration. The conversation highlights the importance of accurate calculations and understanding of rotational dynamics in solving physics problems.
Juliusz
Hydroelectric power station's turbine has a diameter of 7.5m, and a rotation frequency of 94 rotations per minute. What is the turbine's blades acceleration?
P.S. This is translated from another language
a=4π2Rn2
Where n=rotational frequency
My understanding is that I need to convert rotations per minute, to rotations per second for the formula to work. Therefore: 94/60
Though when I plug that in the formula for n, I get a wrong answer.
I also divided the diameter by two to get the radius(R)
4*π2*3.75*(94/60)2≈363.37
The correct answer is 231.7m/s2
Which part of the blade? The tip? The middle? The mass centre? The radius of gyration?
The tip. That's the problem with translating problems from a different language.
Maybe you need to check that calculation.
PS That said, it looks to me like you are correct. I can't see where they get the other answer from.
Likes Juliusz
The ratio between your answer and the "correct" answer is 94/60 (to within 0.1%). It is possible that the supposedly correct answer is not, in fact, correct and that the answer key did not properly square the rotational frequency (as you have it) or the inverse time per rotation (as I usually remember the formula).
Likes Juliusz and PeroK
This is not the first time that a "correct" answer is actually wrong. Thank god for forums like these, otherwise I would break my head thinking about what I did wrong.
Is this the formula you are referring to?
I solved this problem another way.
I used the two equations:
v= 2(pi)r/T
a=v^2/r
where:
r = radius
T= period
v= velocity
a= circular acceleration
I first found v:
2pi(3.75)/(60/94)
v=36.9m/s
a= 36.9^2 / 3.75 = 363.4m/s^2
Timothy Proudkii said:
I solved this problem another way. However, I think I did something terribly wrong because I am no where near what you got.
v= 2(pi)r/T
a=v^2/r
where:
r = radius
T= period
v= velocity
I first found v:
2pi(3.75)/(94/60)
v=15.04m/s
a= 15.04^2 / 3.75 = 60.32m/s^2
What the period, ##T##, if it's 94 revs per minute?
Since there is 94 revolutions per 60 seconds, then there are 1.57 revolutions per second (94/60) Right? Or do I not understand something?
So, what's the period? Which is the time for a revolution.
One second
One second
Is that your answer? Why would it be ##1s##?
"In mathematics, a periodic function is a function that repeats its values in regular intervals or periods" The blade does a full rotation in 1.57s, I misunderstood your initial question.
And, if it did ##1,000## revs per minute, what would be the period?
Likes NotKepler
16.16 revs per one second.
That's not a period. That's a frequency. The period is the length of time it takes for a revolution.
That ties in with how you tried to calculate your velocity, which was ##2\pi r/T##, where ##r## is the radius of the motion.
Likes NotKepler
AHhhhhH I see, so the period would be 0.06s for 1000 revs per minute?
Yes, in general, period = 1/frequency.
Likes NotKepler
Yes thank you!
$$\frac{\pi^2R}{T^2}=4$$
[rewrote attached formula using LaTeX]
No, that's not what I had in mind. The formula that I learned many years ago was$$a=\frac{4\pi^2r}{t^2}$$
Which is the same as $$a=4\pi^2rn^2$$The only difference is that one uses complete rotations per unit time (n) and the other uses time per complete rotation (t).
I don't know what formula you quoted, but the one attached in my image is the same as you just wrote
Take a look at the thumbnail presentation of the attached image from your post #7.
The attachment is fine. The thumbnail is not.
