Chain Rule Confusion (Euler-Lagrange Equation)
  • Thread starter Thread starter laser1
laser1
No explicit x dependence for E-L eq.
Euler-Lagrange.
The above image is from my lecturer's notes.
My concern is when it seems like my lecturer has split up the dF/dx term into dF/dy y' + dF/dy' y''. Why is it this as opposed to ##\frac{\partial F}{\partial y}## etc.? Or would this not matter, because y is an independent variable, and hence, the partial F wrt y = total F wrt y? (although I guess y has to be a function of x...)
Thank you!
Not ##dF/dx = (\partial F/\partial y) y’ - (\partial F/\partial y’) y’’##, it is ##(\partial F/\partial y) y’ +(\partial F/\partial y’) y’’##. This is just the chain rule.
sorry, edited!
I don’t see the issue then. The total d/dx has to be decomposed using the chain rule.
It makes no sense to talk about a total derivative wrt y.
my lecturer uses the notation ##dF/dy## in the second last term. I am confused why it is not ##\partial F/\partial y## instead.
Yeah ok, that’s just sloppy.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
