Change in momentum after hitting a wall
The discussion revolves around calculating the change in momentum when a 1.0 kg ball traveling at 4.0 m/s strikes a wall and bounces back at 2.0 m/s. The correct answer for the change in momentum is determined to be 6 kg m/s, corresponding to option C. The user initially miscalculated the change in momentum as 2 kg m/s, not accounting for the direction of the velocities. The importance of considering the sign associated with velocity in momentum calculations is emphasized. This highlights a common error in physics problems involving momentum and direction.
gake
32) The change in momentum, in kg m/s, that occurs when a 1.0 kg ball traveling at 4.0 m/s strikes a wall
and bounces back at 2.0 m/s is
A) 2.
B) 4.
C) 6.
D) 8.
Answer: C
Momentum==Mass*Velocity
I get A.
Momentum1==1*4
Momentum2==1*2
Momentum1-Momentum2==2
Consider the "sign" associated with the two velocities.
What a dumb mistake! Thanks :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
