Change of capacitors in voltage multiplyer
The discussion centers on a voltage multiplier used for biasing a photomultiplier tube, where original resin-impregnated paper capacitors were replaced with polyester capacitors, changing the capacitance from 56 nF to 68 nF. This replacement led to an increase in ripple current in the DC output, rising from 7mV to 30mV. Initial inquiries focused on the equivalent series resistance (ESR) and equivalent series inductance (ESL) values of the capacitors, but measurements did not show significant differences. Simulations in LTSpice did not replicate the observed increase in ripple current. Ultimately, the user determined that the ripple current issue was unrelated to the capacitor change and is now investigating potential voltage leaks elsewhere in the system.
lucvh
Hi,
I have a supply for biasing a photomultiplyer tube in a plessey ratemeter. In the supply there is a voltage multiplyer of the Villard cascade type, with a filter after it.
The voltage multiplyer is supplied with a 9kHz supply of 300v p-p.
We replaced the original capacitors, which were a resin impregnated paper dilectric (WIMA Durolit) with a polyester dilectric capacitor. The value of capacitange has changed from 56 nF to a preferred value of 68 nF.
When we changed the capacitors over, we notived an increase in ripple current in the DC output from around 7mV to around 30mV.
Can anyone shed any light on what may have caused this?
Thanks, Luc
lucvh said:
Hi,
Thanks, Luc
What are the ESR and ESL values for the two types and values of capacitors?
I couldn't find the values in the specification sheets so i tried to measure the ESR the other day using a 9kHz square wave but i couldn't see any discernable difference between the two, although i cannot garuantee my test was completely accurate as i have never preformed it before.
I have run a few simulations on LTSpice adjusting the ESI and ESR values but it did not seem to have the magnitude of increase in ripple current that i am seeing in reality.
Disregard this thread, the increase in ripple current is caused somewhere else, i checked the HT board in another ratemeter and found there to be a much lower ripple.
Now i just have to find out where the damn voltage is leaking from.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
