- #36
Baluncore
2023 Award
- 15,711
- 9,446
False. For the same bandwidth technology, a digital processor will produce results more than 100 times faster than any analogue computer, with or without changes of parameters. A digital signal never has to settle to a fixed value, it need only be clear of the transition threshold. An analogue circuit requires more time and a lower noise environment. It is unlikely that the errors of an analogue computer at speed will be much less than 0.4%, equivalent to 8 bits. We can do a great many 16 bit digital computations, (with less than 0.004% error), in the time it takes one analogue signal to settle.Kirana Kumara P said:Still, we can expect the analog computer to be faster than a digital computer only if changing the connections (or switching) does not take significant amount of time.
A finite array of analogue computer elements is still FEM.Kirana Kumara P said:One of the methods of solving the above problem could be to make use of the finite element method (although it may be possible to solve the differential equations directly by building a suitable analog computer, without making use of the finite element method).
You are correct, there are many problem dependent possibilities. Without specifications, or a set of equations, anything is possible. It seems like you are trying faithfully to maintain a belief in analogue computers, while all the evidence suggests they have been extinct for quite some time.Kirana Kumara P said:Of course, the answer to the above question may be problem dependent.
I no longer expect you to present specifications and equations, as to do that would threaten your faithfully held belief.
