Changing force on a moving object
  • Thread starter Thread starter trilex987
    Force
The discussion centers on calculating the position and speed of an object influenced by a time-dependent force, such as an AC electric field. It highlights the complexity of integrating force when it varies with both time and space, emphasizing that one cannot simply integrate over time without considering the object's position. The conversation includes a mathematical approach, where force is expressed as a function of time, leading to velocity and position calculations through integration. However, the challenge arises when the force is dependent on both time and spatial variables, complicating the integration process. Understanding these dynamics is crucial for accurately modeling the object's motion under such conditions.
trilex987
Hi there
If an object is affected by space-dependent force (for example wind , or electric field, or whatever), one can calculate its speed at any point in space by integrating the acceleration along its path, but what about if the force was time dependent , like for example an AC electric field, so you need to consider time also.
So how does one go about calculating the objects position and speed at any point in time?
Let's simplify it to just one dimension, for examplethanks
Let us take a simple example. There is a body of mass 'm' Kg which experiences a force that is a linear function of time, F=kt acting in the direction of motion. Let us try to calculate the Work done by the force in a time 'T'. Final Velocity 'v'= integral {(from 0 to T) of [F/m dt]}. Hence work done = change in kinetic energy = 1/2*m*v*v.
trilex987 said:
Hi there
I'm not exactly sure if I read this problem correct, because it looks rather... er ... obvious.
If you have F(t), then one can write F(t) = ma, or a = F(t)/m.
Doing the integration with respect to t will give you the velocity, and a subsequent integration will give you the position, i.e.
a = \frac{dv}{dt} = \frac{F(t)}{m}
This means that
v = \int{\frac{F(t)}{m}dt}
Similarly with position x, since v = dx/dt.
Zz.
Sir. That's exactly what i have done above except that i have not used the symbols that you have.
Except that I dealt with the more general situation, and I didn't try to confuse the OP by including "work done" and "kinetic energy", which isn't part of the question.
Zz.
Thank you both, but you are talking about force as a function of time only.
What I'm talking is a force as a function of both space and time.
For example. an electrode with a time changing electric field, and force upon a free charge.
As the charge moves away from its initial position, it experiences a change in force both as a function of time and position.
That way you can't integrate over time without knowing exactly where is the object positioned in space in each dt moment, and vice versa
you can't integrate over space because you need to know when exactly is the object located at a dx location
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
